Editing configuration files
Hi Guys
When typing in the configuration file , want to check a few things.
When you do a large indent do use on the space bar or do you use the TAB button ?
When you use the dash is there usually a space between the next text letter ?
Just want to make sure that when I enter a line that I am tying in the code correctly.
Basically not sure that I am doing the " indents " correctly.
You need to use spaces, but most text editors allow you to configure the tab button to enter a number of spaces rather than the tab character.
I always have a space, but Iā€™m not sure if it is required or it just makes it look neater :wink:
