Editing Lovelace Views with a misformed URL
Editing Lovelace views through the UI (no Yaml)
Added a view with a url (/room/office) and now when I click the the tab to open the office view it goes back to my home grid.
I also can’t get it to select to edit either.
I have no idea how to remove or edit or otherwise fix this view.
output24
When in edit mode for the dashboard, enter “Raw configuration editor” in the top right:
You should be able to edit it that way. Probably easiest to just Ctrl+f and search for it.
I looked and looked for something like this. Thank you so much!
Raw Configuration editor worked immediately and everything is fixed!
Should have known, thanks dawgy
