EDL21 is not reading via USB port anymore since upgrade to 2026.5.1
I tried now three times to upgrade to 2026.5.1 but everytime the EDL21 is not reading the usb IR meter reader.
The system detects correctly the usb port and the EDL21 is correctly setup to read from usb0.
2026-05-15 14:31:14.384 homeassistant kernel: cp210x 2-1:1.0: cp210x converter detected
2026-05-15 14:31:14.385 homeassistant kernel: usb 2-1: cp210x converter now attached to ttyUSB0
But only one value is read and then the process stops.
When I return to the previous April version, it works always fine. Since there are some changes in the new release regarding IR devices, I have now the suspicion that something is not tested properly. Has anybody an idea about the root cause or if someone else has detected this issue as well.?
I have this issue also.
thanks for your confirmation that I am not the only one that is struggling with the issue :slight_smile:
Ich have exactly the same issue. I've tried two upgrades now with 2026.5 and 2026.5.2 and had always to revert back to 2026.4.4. After each restart, I do only get one reading and then the process stops.
Thanks for your feedback and that it still does not work with 2026.5.2 so that I can save a test and a roll-back again. Looks that we have to wait for the developers to pick up the issue.
I have also this problem. I think here it was working with 2026.5. I haven't seen that isn't updating the values anymore because there was always a value on my main dashboard visible. But it was over the past days always the same number as I found out now.
It's working! I updated now to 2026.5.3 and I can see changing values :slight_smile:
thanks for the hint that the 2026.5.3 works now, I will test it asap as well
I updated now to 2026.06.3 and the issue did not show up again.
Hello all,
same problem here.
I have a RS32-Device running with USB-Connector.
Everything worked well (Raspberry Pi 4 / 8GB) until I have upgraded to 2026.7.
No USB-Devices detected anymore.
After rollback to version 2026.6, all USB-Devices detected.
This means that with the Update of 2026.7 or later, no USB-Ports are detected anymore.
I have tried total reboot (not just HA), without success.
For now, I use the 2026.6 version again.
