EDS bus from Worlddatabus
Hi. Has anybody tried to control a home automation system which uses the EDS bus? It is an Italian standard, based on RS-232, featuring a 3-wire bus connecting small hubs. I currently use these hubs to control all of the lights in my home, plus shutters and some outlets. I would like to use HA to provide a UI for phones/tablets and then build upon the systems using other hubs and devices.
hello! did you find a solution to control the EDS bus with HA? I’ve tje same question…
many many thanks
