The bathroom is being reconstructed and we want to add electric floor heating. But I want to control this via HomeAssistant. Any good suggestions for a brand and type?
It has to be a version that can be put between the concrete and the tiles. Looking forward to some suggestions.
So these devices are the controllers to switch on/off the electric heating device. This vendor doesn’t include/provide the actual heating system (for in the floor) itself?
So you need to buy a heating system on which you can replace the thermostat with a Z-wave type controlled device. Is my assumption correct?
Thanks for the suggestion. This is the thermostat only. The assumption with this solution is that the thermostat of the heating floor system can be replaced by this device, correct?
Correct.Sorry, I didn’t read it properly and thought that the heating mats were already installed.
I used the Meross MTS200 to replace existing analog thermostats that weren’t smart.
