Elro 433 MHz switches and Tasmota / Portisch codes
Hello everyone, I’m looking for a solution to the following problem:
My Sonoff RF Bridge V2 is running Tasmota and Portisch. I want to connect this bridge to Home Assistant via MQTT.
I’m still using the old Elro Flamingo 433 MHz switched sockets, as they always worked well for me with Pimatic.
However, I’m using switching codes that aren’t found on the standard remote controls (A to D / On-Off).
For example one device is switched by “R ON or OFF”
Consequently, I can’t simply pair my Sonoff RF Bridge with the devices by lerarning; I would have to manually define the codes for each device.
But since I only receive raw codes from the Tasmota sniffer, I don’t know what these raw codes should look like.
And Tasmota/Portisch doesn’t seem to understand the Elro codes 01110 11100.
Does anyone have a solution for how I can get this to work?
Is there an online converter “Elro to RAW / RAW to Elro” ???
Many thanks and best regards.
If you get the codes from the tasmota running log, you can format them / use them like this…
I did not think the v2 could run portisch.
It can. Search on youtube.
How I can get codes from tasmota log, if I could not send those signals due to the fact, that the wanting codes are out of range of my remote buttons ?
