In my house I have Elro Connect, that is a connector for my fire and also has some additional sensors. I would like that to combine is with my zwave configuration in Home Assistant.
Is there already a component or how can I setup the integration.
thanks for your response. I have looked in the list and did not find any information. Is this the best place to ask for people who maybe worked with it?
I’ve been publishing a PR https://github.com/home-assistant/core/pull/71113 to implement elro_connects as an integration.
Initially this will implement the siren platform and support the fire/smoke/CO/water and heat alarm type devices. To test the alarm the siren can be switched on. Turning the switch off will silence the (test) alarm.
Later sensors for battery, signal and device_state will be added.
Hi, very nice solution…i have also a gateway and three smoke sensors, the devices looks like yours and the app which i have to use called family well…is it possible to connect my devices to the elro app or the home assistant intigration with the familywell app?
Installed HACS and elro connect, my only question i have at this moment how do i then add the devices which are connected ? Or should this be done automaticly after xx minutes ?
