I played a bit according the documentation.
After a First POST with the Login I got the AccessToken.
Then I could start a GET and received some data:
"device" : {
"manufacturer" : "Eltako",
"lastSeen" : "",
"deviceType" : "DSZ15DZMOD",
"friendlyId" : "",
"busAddress" : 1,
"functions" : [
"value" : 226.22999999999999,
"key" : "Voltage of L1 to N",
"timestamp" : "2026-02-04T18:35:40+0100",
"unit" : "Volt"
"value" : 222.31,
"key" : "Voltage of L2 to N",
"timestamp" : "2026-02-04T18:35:41+0100",
"unit" : "Volt"
"value" : 232.61000000000001,
"key" : "Voltage of L3 to N",
"unit" : "Volt"
"value" : 1.76,
"key" : "L1 Current",
"unit" : "A"
"value" : 2.4900000000000002,
"key" : "L2 Current",
"unit" : "A"
"value" : 1.1000000000000001,
"key" : "L3 Current",
"unit" : "A"
"value" : 233,
"key" : "L1 active power",
"unit" : "Watt"
"value" : 466,
"key" : "L2 active power",
"unit" : "Watt"
"value" : 141,
"key" : "L3 active power",
"unit" : "Watt"
"value" : 0.58299999999999996,
"key" : "L1 power factor",
"unit" : ""
"value" : 1,
"key" : "L2 power factor",
"unit" : ""
"value" : 0.54800000000000004,
"key" : "L3 power factor",
"unit" : ""
"value" : 841,
"key" : "Total active power",
"unit" : "Watt"
"value" : 0.69399999999999995,
"key" : "Total power factor",
"unit" : ""
"value" : 12.66,
"key" : "Total imported active energy",
"unit" : "kWh"
"value" : 1.0900000000000001,
"key" : "Total exported active energy",
"unit" : "kWh"
"firstSeen" : "",
"forwardOnMqtt" : false
I searched a bit but accordinf the documentation I can’t use it like the - if I see it correct?
According the documentation, the access Token is only 15min valid - then a new login / token is needed.
Do I need an integration for this? Or is there an integration available?
