I also had it 2 times, but I couldn’t find any logs.
EMHASS just stopped and a restart of the addons fixes it.
I will temporary make an automation to restart emhass
I also having same problems.
The current add-on test image fix the crashing issue. You can use that in the meantime. Just copy your configuration in the test image configuration and your are done. Of course the fix will be available in the next release
Emhass 0.16.2 is released and should fix the crashing issue.
@davidusb
I still have the issue that when I’m on the configuration page I cannot switch anymore between the “graphical” and “code-style” view. There is no reaction when I click “<>”.
I removed the 0s (zeros) from the ‘operating_hours_of_each_deferrable_load’: [None, None, None, None] and since then the problem exists. (I see this in the logs)
Is there any other place (e.g. in the file system) where I can update "operating hours of each def load to : ‘operating_hours_of_each_deferrable_load’: [0, 0, 0, 0] again?
Thanks for your help
Yes you can try to manually modify the options.json file inside the add-on docker image. It depends on where you’re storing your config.json. Two options either inside the add-on container or in the “share” folder in Home Assistant. You’ll need the Terminal & SSH add-on.
Follow this procedure from gemini:
Here is the procedure to modify the configuration, covering both the internal method (installing nano) and the external method (editing via the share folder), which is much easier for most users.
This is the easiest method because you can access the file directly from your computer if you have the Samba Share add-on, or simply use the File Editor add-on in Home Assistant.
config.json is typically located in your Home Assistant’s /share directory./share/config.jsonUse this if you cannot access the file externally or need to edit files that are not exposed to the /share folder.
1. Find the EMHASS Container ID
Open the Terminal in Home Assistant and run:
docker ps | grep emhass
Copy the Container ID (e.g., a1b2c3d4e5).
2. Enter the Container
docker exec -it <ID> bash
(If bash fails, try sh)
**3. Install nano**
Since the container is lightweight, it likely lacks an editor. Install one:
apk update && apk add nano
(If that fails, try apt-get update && apt-get install nano)
4. Edit the File
Navigate to the data directory (typically /data or wherever the config resides in the container):
cd /data
nano config.json
Ctrl+O then Enter to Save.Ctrl+X to Exit.5. Restart the Container
Type exit to leave the container, then run:
docker restart <ID>
Important:
If you edit config.json manually, avoid opening the “Configuration” tab in the EMHASS Add-on UI and clicking “Save”, as this may overwrite your manual changes with the old values stored in the UI form.
After update to the latest version I have the following problem. How can I fix this?
WARNING in optimization: MPC Prediction Horizon (56) does not match the initialized optimization window (96). This may cause shape mismatch errors in the solver
Probably the related issue and a possible solution here: Suddenly infeasible after updating to 0.16.1 · Issue #700 · davidusb-geek/emhass · GitHub
That’s it! SOLVED! Thanks a lot.
After removing the addon from HA and installing it again the Warning in optimazation is not there anymore.
But this is still there.
[2026-01-30 14:52:00,920] INFO in forecast: Retrieving weather forecast data using method = open-meteo
[2026-01-30 14:52:00,920] INFO in forecast: Loading existing cached Open-Meteo JSON file: /data/cached-open-meteo-forecast-b.json
[2026-01-30 14:52:00,921] INFO in forecast: The cached Open-Meteo JSON file is recent (age=10m, max_age=30m)
/app/.venv/lib/python3.12/site-packages/scipy/optimize/_chandrupatla.py:437: RuntimeWarning:
invalid value encountered in divide
These seem to happen when the solar irradiance is very close to zero.
The pvlib module handle these very well so you can safely ignore these warnings.
Ok. Thanks.
The solar panels are currently completely covered with snow.
Hi everyone,
I’m running EMHASS with a separate Day-Ahead optimization (once per day) and a short-horizon MPC loop every 15 minutes, and I’d like to better understand the following warning that appears on every MPC run:
WARNING in optimization: MPC Prediction Horizon (16) does not match the initialized optimization window (96).
INFO in optimization: Resizing optimization problem from 96 to 16 timesteps.
Is it correct that I have to reinstall the add-on to solve this warning?
Functionally everything works fine, but I want to make sure this warning is safe to ignore and that I’m using EMHASS as intended.
Thanks a lot for your insights!
What do you mean by short horizon MPC run? It does not need to be short horizon, e.g. I supply it with an horizon until the end of the next day. So up to almost 48 hours * 4 (15 minute timestep). Did you configure the timestep in the config or the commandline? In latter case it might be different between the day-ahead and MPC. Perhaps you can supply the curl/rest commands.
Day-Ahead (runs once in the morning):
delta_forecast_daily = 1optimization_time_step = 15MPC (runs every 15 minutes):
prediction_horizon = 16 (4 hours)optimization_time_step = 15soc_init = current battery SOCsoc_final dynamically derived from the Day-Ahead SOC near the end of the MPC horizonThe MPC payload explicitly contains prediction_horizon = 16.
With the day ahead soc from the morning the soc final meet the soc of the dayahead at this timepoint. This gives a good regulation for the battery load.
Even though the Day-Ahead optimization runs only once per day, the MPC warning appears on every MPC execution.
This suggests that:
Is this expected behavior?
delta_forecast_daily / internal config before reading the MPC payload?to complete the picture here my rest commands and sensors
emhass_mlforecast_fit:
url: "http://192.168.0.38:5000/action/forecast-model-fit"
method: POST
headers:
Content-Type: application/json
payload: >
"historic_days_to_retrieve": 20,
"model_type": "long_train_data",
"var_model": "sensor.qcells_house_load",
"sklearn_model": "KNeighborsRegressor",
"num_lags":96,
"split_date_delta": "48h",
"perform_backtest": "False"
emhass_mlforecast_tune:
url: "http://192.168.0.38:5000/action/forecast-model-tune"
method: POST
headers:
payload: >
"num_lags":96,
emhass_mlforecast_predict:
url: "http://192.168.0.38:5000/action/forecast-model-predict"
method: POST
headers:
payload: >
"model_predict_publish": true,
"model_predict_entity_id": "sensor.p_load_forecast_custom_model",
"model_predict_unit_of_measurement": "W",
"model_predict_friendly_name": "Load Power Forecast custom ML model",
emhass_dayahead:
url: "http://192.168.0.38:5000/action/dayahead-optim"
method: POST
headers:
payload: >
"pv_power_forecast":{{ state_attr('sensor.emhass_solcast_pv_forecast', 'pv_power_forecast') | to_json}},
"delta_forecast_daily": 1,
"optimization_time_step":15,
"load_cost_forecast": {{ state_attr('sensor.emhass_epex_forecast', 'load_cost_forecast') | to_json}},
"load_power_forecast": {{ state_attr('sensor.emhass_load_forecast_dict_local', 'load_forecast') | to_json}}
emhass_naive_mpc_optim_forecast:
url: http://192.168.0.38:5000/action/naive-mpc-optim
method: POST
content_type: "application/json"
timeout: 30
payload: "{{ state_attr('sensor.emhass_mpc_payload','payload') }}"
emhass_publish_data:
url: http://192.168.0.38:5000/action/publish-data
method: POST
content_type: 'application/json'
payload: >-
{"publish_prefix": "{{ prefix | default('') }}"}
template:
- sensor:
- name: "emhass_epex_forecast"
unique_id: emhass_epex_forecast
icon: mdi:script
state: "{{ now() }}" # Irgendein gültiger state, wird von EMHASS ignoriert
attributes:
load_cost_forecast: >
{% set items = state_attr('sensor.epex_spot_data_total_price_3', 'data') %}
{% if not items %}
{% else %}
{%- set ns = namespace(out={}) -%}
{%- for i in items -%}
{%- set ts = as_datetime(i.start_time).strftime('%Y-%m-%d %H:%M:%S%z') -%}
{%- set ts = ts[:-2] ~ ':' ~ ts[-2:] %} {# formatiert +0100 → +01:00 #}
{%- set ns.out = ns.out | combine({ ts: i.price_per_kwh }) -%}
{%- endfor -%}
{{ ns.out }}
{% endif %}
- sensor:
- name: "emhass_load_forecast_dict_local"
attributes:
load_forecast: >
{% set items = state_attr('sensor.p_load_forecast_custom_model', 'scheduled_forecast') %}
{% if not items %}
{% else %}
{# parse original, convert to local timezone #}
{%- set dt = as_local(as_datetime(i.date)) -%}
{%- set ts = dt.strftime('%Y-%m-%d %H:%M:%S%z') -%}
{%- set ts = ts[:-2] ~ ':' ~ ts[-2:] -%}
{%- set val = (i.p_load_forecast_custom_model | float) -%}
{%- set ns.out = ns.out | combine({ ts: val }) -%}
{%- endfor -%}
{{ ns.out }}
{% endif %}
- sensor:
- name: "emhass_solcast_pv_forecast"
icon: mdi:solar-power
attributes:
pv_power_forecast: >
{% set heute = state_attr('sensor.solcast_pv_forecast_prognose_heute', 'detailedForecast') or [] %}
{% set morgen = state_attr('sensor.solcast_pv_forecast_prognose_morgen', 'detailedForecast') or [] %}
{% set items = heute + morgen %}
{% if not items %}
{% else %}
{%- set dt = as_datetime(i.period_start) -%}
{%- if dt -%}
{%- set ts = ts[:-2] ~ ':' ~ ts[-2:] -%} {# formatiert +0100 → +01:00 #}
{%- set ns.out = ns.out | combine({ ts: (i.pv_estimate | float |multiply(1000) ) }) -%}
{%- endif -%}
{%- endfor -%}
{{ ns.out }}
{% endif %}
- sensor:
- name: "emhass_solcast_pv_forecast_bias"
attributes:
{% set bias = states('sensor.pv_bias_faktor') | float(1) %}
{% if not items %}
{% else %}
{%- if dt -%}
{%- set pv = (i.pv_estimate | float * 1000 * bias) | round(0) -%}
{%- set ns.out = ns.out | combine({ ts: pv }) -%}
{%- endif -%}
{%- endfor -%}
{{ ns.out }}
{% endif %}
- sensor:
- name: "emhass_mpc_payload"
attributes:
payload: >
{% set pv_attr = state_attr('sensor.emhass_solcast_pv_forecast_bias', 'pv_power_forecast') or {} %}
{% set load_attr = state_attr('sensor.emhass_load_forecast_dict_local', 'load_forecast') or {} %}
{% set price_attr = state_attr('sensor.emhass_epex_forecast', 'load_cost_forecast') or {} %}
{% set soc_init = (states('sensor.qcells_battery_capacity') | float(0)) / 100 %}
{# --- dynamisches soc_final abhängig von dayahead Lauf --- #}
{# Prediction horizon: 4h = 16 * 15min steps #}
{% set prediction_horizon_steps = 16 %}
{% set horizon_end_ts = as_timestamp(now()) + prediction_horizon_steps * 15 * 60 %}
{% set dayahead = state_attr('sensor.dayaheadsoc_batt_forecast', 'battery_scheduled_soc') or [] %}
{% set ns = namespace(best_diff=999999, best_soc=none) %}
{% for i in dayahead %}
{% set dt = as_timestamp(as_datetime(i.date)) %}
{% set diff = (dt - horizon_end_ts) | abs %}
{% if diff < ns.best_diff %}
{% set ns.best_diff = diff %}
{% set ns.best_soc = (i.dayaheadsoc_batt_forecast | float(50)) / 100 %}
{% endif %}
{% endfor %}
{% set soc_final = ns.best_soc if ns.best_soc is not none else soc_init %}
{# Build payload dict #}
{% set payload = {
"pv_power_forecast": pv_attr,
"load_power_forecast": load_attr,
"load_cost_forecast": price_attr,
"prediction_horizon": prediction_horizon_steps,
"soc_init": soc_init,
"soc_final": soc_final
{{ payload | tojson }}
Look here: Optimization window size mismatch in 0.16.0 · Issue #694 · davidusb-geek/emhass · GitHub
This is related to the delta_forecast_days, you can safely ignore this warning, EMHASS is still working as expected.
Thanks a lot, Ralf
It’s fixed in the latest releases.
Not sure how you copy the sensor, but when making a new template, it’s only filled starting that moment, not the entire history of the original sensor. I think…
Hello all,
I have spent some time now getting EMHASS to work in my fairly simple setup:
The gym is typically used for an hour or so in the mornings, and I want it to be minimum 12 degrees between 9 and 10 am. Outside that window it should be set to 5 degrees minimum.
I run a dayahead optimization about 13 pm, when new 15 minute prices for the next day comes out. The horizon is 24h. Then every 15 min I run an MPC optim with horizon = remaining dayahead window.
It’s about -10 celsius here right now and around 22 pm the gym has cooled down to 5 degrees. In order to heat up to 12 by 9 the next morning, EMHASS calculates heating to start let’s say midnight. The problem is, if reality deviates from the model (for example real temps come in lower than forecast, or thermal model params are a little off), EMHASS optimization becomes infeasible, since it optimizes costs to just barely hit the target temp.
How would you recommend handling this situation?
