<hass address>:8060 in a browser also gives connection refused. I just upgraded to the latest stable version of HA so my full log is quite short, and I am not seeing anything other then the Roku error itself.
The odd Hue and TPLink errors are to be expected - they represent devices in Config that are not currently plugged in!
019-03-29 11:05:16 WARNING (MainThread) [homeassistant.loader] You are using a custom component for huesensor.device_tracker which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-03-29 11:05:16 WARNING (MainThread) [homeassistant.loader] You are using a custom component for huesensor.sensor which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-03-29 11:05:16 WARNING (MainThread) [homeassistant.loader] You are using a custom component for huesensor.binary_sensor which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-03-29 11:05:19 WARNING (MainThread) [homeassistant.components.hue] Connected to Hue at 192.168.2.147 but not registered.
2019-03-29 11:05:19 ERROR (SyncWorker_8) [homeassistant.components.tplink] Unable to connect to device 192.168.2.177: Communication error
2019-03-29 11:05:19 ERROR (Thread-2) [pychromecast.socket_client] [AFTN-158:8010] Exception caught while sending message to controller ReceiverController: Message urn:x-cast:com.google.cast.receiver from receiver-0 to sender-0: {‘requestId’: 1, ‘status’: {‘applications’: [], ‘isActiveInput’: True, ‘volume’: {‘controlType’: ‘attenuation’, ‘level’: 1, ‘muted’: False, ‘stepInterval’: 0.05}}, ‘type’: ‘RECEIVER_STATUS’}
File “/usr/local/lib/python3.7/site-packages/pychromecast/socket_client.py”, line 563, in _route_message
message, data)
File “/usr/local/lib/python3.7/site-packages/pychromecast/socket_client.py”, line 889, in receive_message
self._process_get_status(data)
File “/usr/local/lib/python3.7/site-packages/pychromecast/socket_client.py”, line 1019, in _process_get_status
status = self._parse_status(data, self.cast_type)
File “/usr/local/lib/python3.7/site-packages/pychromecast/socket_client.py”, line 997, in _parse_status
app_data = data[‘applications’][0]
IndexError: list index out of range
2019-03-29 11:05:19 ERROR (MainThread) [homeassistant.components.device_tracker] Unable to load /config/known_devices.yaml: Config file not found: /config/known_devices.yaml
2019-03-29 11:05:22 ERROR (SyncWorker_8) [homeassistant.components.tplink] Unable to connect to device 192.168.2.178: Communication error
2019-03-29 11:05:25 ERROR (SyncWorker_8) [homeassistant.components.tplink] Unable to connect to device 192.168.2.179: Communication error
2019-03-29 11:05:28 ERROR (SyncWorker_8) [homeassistant.components.tplink] Unable to connect to device 192.168.2.181: Communication error
2019-03-29 11:05:50 ERROR (MainThread) [homeassistant.core] Error doing job: Future exception was never retrieved
File “/usr/local/lib/python3.7/site-packages/urllib3/connection.py”, line 159, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw)
File “/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py”, line 80, in create_connection
raise err
File “/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py”, line 70, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 600, in urlopen
chunked=chunked)
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 354, in _make_request
conn.request(method, url, **httplib_request_kw)
File “/usr/local/lib/python3.7/http/client.py”, line 1229, in request
self._send_request(method, url, body, headers, encode_chunked)
File “/usr/local/lib/python3.7/http/client.py”, line 1275, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File “/usr/local/lib/python3.7/http/client.py”, line 1224, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File “/usr/local/lib/python3.7/http/client.py”, line 1016, in _send_output
self.send(msg)
File “/usr/local/lib/python3.7/http/client.py”, line 956, in send
self.connect()
File “/usr/local/lib/python3.7/site-packages/urllib3/connection.py”, line 181, in connect
conn = self._new_conn()
File “/usr/local/lib/python3.7/site-packages/urllib3/connection.py”, line 168, in _new_conn
self, “Failed to establish a new connection: %s” % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x6f4cc9b0>: Failed to establish a new connection: [Errno 111] Connection refused
File “/usr/local/lib/python3.7/site-packages/requests/adapters.py”, line 449, in send
timeout=timeout
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File “/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py”, line 398, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host=‘192.168.2.170’, port=8060): Max retries exceeded with url: /query/device-info (Caused by NewConnectionError(’<urllib3.connection.HTTPConnection object at 0x6f4cc9b0>: Failed to establish a new connection: [Errno 111] Connection refused’))
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/roku/init.py”, line 51, in roku_discovered
CONF_HOST: info[‘host’]
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/roku/init.py”, line 100, in _setup_roku
r_info = roku.device_info
File “/usr/local/lib/python3.7/site-packages/roku/core.py”, line 213, in device_info
resp = self._get(’/query/device-info’)
File “/usr/local/lib/python3.7/site-packages/roku/core.py”, line 172, in _get
return self._call(‘GET’, path, *args, **kwargs)
File “/usr/local/lib/python3.7/site-packages/roku/core.py”, line 189, in _call
resp = func(url, *args, **kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 546, in get
return self.request(‘GET’, url, **kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 533, in request
resp = self.send(prep, **send_kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 646, in send
r = adapter.send(request, **kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/adapters.py”, line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host=‘192.168.2.170’, port=8060): Max retries exceeded with url: /query/device-info (Caused by NewConnectionError(’<urllib3.connection.HTTPConnection object at 0x6f4cc9b0>: Failed to establish a new connection: [Errno 111] Connection refused’))
