I’m new to HA, and I’m trying to set up a bare-metal installation on a Pi 5; software versions are Core: 2025.2.4, Supervisor: 2025.02.1, Operating System: 14.2, and Frontend: 20250214.0. I have the basics working, but now I want to set up non-root SSH so I can use Ansible to retrieve my backups. (I know using a NAS would be easier, but I’ve not yet either the knowledge nor the financial wherewithal.)
Most of the instructions I’ve found online seem outdated, as they refer to system settings that do not exist on my installation. I’ve tried to follow Debugging the Home Assistant Operating System, but I’m still getting [email protected]: Permission denied (publickey). when I try to connect. Also, I appear to be connecting as root, which I do not want; how do I create a “normal” (non-root) user on HA?
You need to look at the logs, try things is HA working. You listed a supervisor versionand bare metal, I assumed you meant HAOS install but if you are on supervised you probably have things set-up wrong. (Because there is 1 right way and 17575874 wrong ways with supervised mode.)
Mostly. I can’t control my Sensi thermostat anymore (This was a reinstall from scratch, without backups) and one (of two) Z-wave switch that won’t connect, but I suspect that’s a range issue. Everything else seems okay. My Zigbee stuff works, and my apps work as well.
