Enable or Disable Motion Detection on Amcrest Camera through Camera Service
I noticed that there is a service to “enable_motion_detection” and “disable_motion_detection” within Home Assistant.
This doesn’t appear to be working when I try to run it. I currently use Curl commands and a script to enable and disable motion detection. Is there a way to get this working through the service?
Same issue for me.
Can you, please, share the Curl command you use ?
