Hi everyone.
I have removed the original firmware from an Enbrighten 58185-S1 Motion Security Light following a cloudcutter guide.
All went well and it now has ESPhome running on it.
After completing the flashing, I found out too late that there is no control of it with ESPhome.
Looking at other devices that can be ‘cut’, they have .yaml files available to be installed which define pins and input/output functions.
My light has a very basic .yaml with no pins defined.
Has anyone else ‘cut’ one of these devices and figured out how configure it for control?
Looks like my title needs to be improved/reworded. I’ll edit it, remove ‘wifi’…
It is successfully flashed. It has a wifi connection, i can connect to it through wifi but I cannot control any of its original functions as the ESPhome yaml does not encode any of the pin functions. eg turn the light on or off, turn on or off the accent light ring…
I have noticed there is a dropdown for the pins in the web portal. Do I have to trial and error to see what they control and manually config this light as the prebuilt device configuration doesn’t generate yaml that configures the pins?
(Note, this is my first time using thsese tools so literally learning as I go…)
The yaml that was uploaded is the basic profile from UPK2ESPHome:
Ok - start by going to the site linked below. Your device is not listed but if you can find an identical looking device (these things are often just rebranded) then you could try adding yaml for the listed control GPIOs.
Ignore that it says Tasmota - the pins are all we are interested in.
Hi I’ve gone through the device list on the Tasmota site but do not see anything similar.
I started messing with the dropdowns on the web portal and the device is now not connecting to wifi. I had done a reboot then factory reset but its not available as a web portal, and I do not see it when I scan my wifi.
I will dig out my raspi with cloudcutter on it and see if I can reconnect/discover the device.
After buggering it up I found a similar looking device on the cloudcutter github but can’t try anything with its yaml until I recover my device…
Let you know how it goes.
