I’ve been tormenting the unfortunate code all evening, getting lost in three pines))) Even gpt4 didn’t help me.
The goal is still to study (perhaps in the future I would like to make a reference voltage regulator for TL494 and there are many other ideas, but for this you need to adjust the borehole) but first, I want to figure out how to smoothly adjust the borehole of the PWM signal with a given current frequency using the encoder: one click clockwise +1% fill, and -1% counterclockwise rotation . While some nonsense is being obtained , when rotating in both directions , only a decrease in filling occurs, if you turn sharply clockwise, it can only start to increase %, regardless of which way to rotate , until you turn the encoder sharply again , which can switch the direction of adjustment Here is my code and a little bit of logs :
esphome:
friendly_name: Wemos d2
esp8266:
board: d1_mini
logger:
level: DEBUG
api:
ota:
- platform: esphome
wifi:
networks:
- ssid: Pro4
password: Milk33kg
- platform: rotary_encoder
pin_a: D1
pin_b: D2
resolution: 1
on_value:
then:
- lambda: |-
float current_level = id(pwm_level);
current_level += (x > 0) ? 1.0 : -1.0; // Увеличиваем или уменьшаем уровень
current_level = clamp(current_level, 0.0f, 100.0f); // Ограничиваем уровень от 0 до 100%
id(pwm_level) = current_level; // Обновляем уровень заполнения
id(my_pwm_output).set_level(current_level / 100.0f); // Устанавливаем новый уровень (0.0 до 1.0)
// Логирование для отладки
ESP_LOGD("custom", "Current level: %f, Encoder value: %d", current_level, x);
globals:
- id: pwm_level
type: float
restore_value: no
initial_value: '50.0' # Начальное значение уровня
output:
- platform: esp8266_pwm
pin: D5
frequency: 1000 Hz # Фиксированная частота
inverted: false
switch:
turn_on_action:
- output.set_level:
level: 0.0
[01:48:48][D][sensor:093]: 'Rotary Encoder': Sending state -10.00000 steps with 0 decimals of accuracy
[01:48:48][D][custom:037]: Current level: 19.000000, Encoder value: 0
[01:48:48][D][sensor:093]: 'Rotary Encoder': Sending state -11.00000 steps with 0 decimals of accuracy
[01:48:48][D][custom:037]: Current level: 18.000000, Encoder value: 0
[01:48:48][D][sensor:093]: 'Rotary Encoder': Sending state -12.00000 steps with 0 decimals of accuracy
[01:48:48][D][custom:037]: Current level: 17.000000, Encoder value: 0
[01:48:48][D][sensor:093]: 'Rotary Encoder': Sending state -13.00000 steps with 0 decimals of accuracy
[01:48:48][D][custom:037]: Current level: 16.000000, Encoder value: 0
[01:48:49][D][sensor:093]: 'Rotary Encoder': Sending state -14.00000 steps with 0 decimals of accuracy
[01:48:49][D][custom:037]: Current level: 15.000000, Encoder value: 0
[01:48:49][D][sensor:093]: 'Rotary Encoder': Sending state -15.00000 steps with 0 decimals of accuracy
[01:48:49][D][custom:037]: Current level: 14.000000, Encoder value: 0
[01:48:50][D][sensor:093]: 'Rotary Encoder': Sending state -14.00000 steps with 0 decimals of accuracy
[01:48:50][D][custom:037]: Current level: 13.000000, Encoder value: 0
[01:48:51][D][sensor:093]: 'Rotary Encoder': Sending state -13.00000 steps with 0 decimals of accuracy
[01:48:51][D][custom:037]: Current level: 12.000000, Encoder value: 0
[01:48:51][D][sensor:093]: 'Rotary Encoder': Sending state -12.00000 steps with 0 decimals of accuracy
[01:48:51][D][custom:037]: Current level: 11.000000, Encoder value: 0
[01:48:51][D][sensor:093]: 'Rotary Encoder': Sending state -11.00000 steps with 0 decimals of accuracy
[01:48:51][D][custom:037]: Current level: 10.000000, Encoder value: 0
[01:48:52][D][sensor:093]: 'Rotary Encoder': Sending state -10.00000 steps with 0 decimals of accuracy
[01:48:52][D][custom:037]: Current level: 9.000000, Encoder value: 0
[01:48:52][D][sensor:093]: 'Rotary Encoder': Sending state -9.00000 steps with 0 decimals of accuracy
[01:48:52][D][custom:037]: Current level: 8.000000, Encoder value: 0
[01:48:52][D][sensor:093]: 'Rotary Encoder': Sending state -8.00000 steps with 0 decimals of accuracy
[01:48:52][D][custom:037]: Current level: 7.000000, Encoder value: 0
[01:48:54][D][sensor:093]: 'Rotary Encoder': Sending state -9.00000 steps with 0 decimals of accuracy
[01:48:54][D][custom:037]: Current level: 6.000000, Encoder value: 0
[01:48:54][D][sensor:093]: 'Rotary Encoder': Sending state -10.00000 steps with 0 decimals of accuracy
[01:48:55][D][custom:037]: Current level: 5.000000, Encoder value: 0
[01:48:55][D][sensor:093]: 'Rotary Encoder': Sending state -11.00000 steps with 0 decimals of accuracy
[01:48:55][D][custom:037]: Current level: 4.000000, Encoder value: 0
[01:48:55][D][sensor:093]: 'Rotary Encoder': Sending state -12.00000 steps with 0 decimals of accuracy
[01:48:55][D][custom:037]: Current level: 3.000000, Encoder value: 0
[01:48:55][D][sensor:093]: 'Rotary Encoder': Sending state -13.00000 steps with 0 decimals of accuracy
[01:48:55][D][custom:037]: Current level: 2.000000, Encoder value: 0
