I’ve spent the last day trying to figure out what the issue is, it seems to have manifested since the latest HA update and it killing my HA instance. This is flying through the logs repeating over and over.
2025-01-13 08:52:58.749 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template<template=(mushroom-shape-icon {
{% set vol_level = state_attr(config.entity, 'volume_level') | float %}
--card-mod-icon:
{% if state_attr(config.entity, 'is_volume_muted') == true %}
mdi:volume-mute
{% else %}
{% if vol_level > 0.66 %}
mdi:volume-high
{% elif vol_level < 0.33 %}
mdi:volume-low
{% else %}
mdi:volume-medium
{% endif %}
{% endif %};
}) renders=30362>
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2364, in forgiving_float_filter
return float(value)
TypeError: float() argument must be a string or a real number, not 'NoneType'
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 643, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2745, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.13/site-packages/jinja2/environment.py", line 1295, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.13/site-packages/jinja2/environment.py", line 942, in handle_exception
raise rewrite_traceback_stack(source=source)
File "
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2367, in forgiving_float_filter
raise_no_default("float", value)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1921, in raise_no_default
raise ValueError(
...<2 lines>...
ValueError: Template error: float got invalid input 'None' when rendering template 'mushroom-shape-icon {
--card-mod-icon:
mdi:volume-mute
{% else %}
mdi:volume-high
mdi:volume-low
{% else %}
mdi:volume-medium
{% endif %}
{% endif %};
}' but no default was specified
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 760, in async_render_to_info
render_info._result = self.async_render( # noqa: SLF001
variables, strict=strict, log_fn=log_fn, **kwargs
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 645, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: ValueError: Template error: float got invalid input 'None' when rendering template 'mushroom-shape-icon {
--card-mod-icon:
mdi:volume-mute
{% else %}
mdi:volume-high
mdi:volume-low
{% else %}
mdi:volume-medium
{% endif %}
{% endif %};
2025-01-13 08:52:58.751 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template<template=(mushroom-shape-icon {
--card-mod-icon:
mdi:volume-mute
{% else %}
mdi:volume-high
mdi:volume-low
{% else %}
mdi:volume-medium
{% endif %}
{% endif %};
}) renders=30364>
return float(value)
File "
raise ValueError(
...<2 lines>...
--card-mod-icon:
mdi:volume-mute
{% else %}
mdi:volume-high
mdi:volume-low
{% else %}
mdi:volume-medium
{% endif %}
{% endif %};
--card-mod-icon:
mdi:volume-mute
{% else %}
mdi:volume-high
mdi:volume-low
{% else %}
mdi:volume-medium
{% endif %}
{% endif %};
I found that I had a few Mushroom Media Card’s with the following card-mods which matched the error. I have since removed this config and restarted HA but it’s not gone away.
Before:
type: custom:mushroom-media-player-card
show_volume_level: true
volume_controls:
- volume_set
- volume_mute
- volume_buttons
use_media_info: false
layout_options:
grid_columns: 4
grid_rows: 2
entity: media_player.revo
card_mod:
style: |
--card-mod-icon:
mdi:volume-mute
{% else %}
mdi:volume-high
mdi:volume-low
{% else %}
mdi:volume-medium
{% endif %}
{% endif %};
After
volume_controls:
- volume_set
- volume_mute
- volume_buttons
layout_options:
grid_columns: 4
grid_rows: 2
