Enelever error studio code server
Hello i am trying to get this added to configuration.yaml
and automations.yaml. but when check configuration before restart.
it says this
Configuratiewaarschuwingen
Invalid config for 'command_line' at configuration.yaml, line 44: 'triggers' is an invalid option for 'command_line', check: command_line->1->triggers
Invalid config for 'command_line' at configuration.yaml, line 45: 'resource' is an invalid option for 'command_line', check: command_line->1->resource
Invalid config for 'command_line' at configuration.yaml, line 46: 'name' is an invalid option for 'command_line', check: command_line->1->name
Invalid config for 'command_line' at configuration.yaml, line 47: 'scan_interval' is an invalid option for 'command_line', check: command_line->1->scan_interval
Invalid config for 'command_line' at configuration.yaml, line 48: 'value_template' is an invalid option for 'command_line', check: command_line->1->value_template
Invalid config for 'command_line' at configuration.yaml, line 49: 'json_attributes' is an invalid option for 'command_line', check: command_line->1->json_attributes
  # Enever.nl stroomprijzen
  - triggers: rest
    resource: https://enever.nl/api/stroomprijs_vandaag.php?token=my code is removed here
    name: Enever Stroomprijs ANWB
    scan_interval: 86400
    value_template: "OK"
    json_attributes:
      - data
    sensors:
      stroomprijs_anwb:
        device_class: monetary
        unit_of_measurement: €/kWh
        unique_id: "enever_stroomprijs_anwb"
        value_template: >
          {% set now_ts = as_timestamp(utcnow()) %}
          {% set values = namespace() %}
          {% set values.current = None %}
          {% for row in states.sensor.enever_stroomprijs_anwb.attributes.data|reverse if not values.current %}
          {% set row_timestamp = as_timestamp(row.datum) %}
          {% if now_ts > row_timestamp %}
          {% set values.current = row %}
          {% endif -%}
          {% endfor -%}
          {% if values.current %}
          {{ values.current.prijsANWB }}
          {% else %}
          {{ states(entity_id) }}
          {% endif %}
        friendly_name: "Stroomprijs ANWB"
  # Enever.nl gasprijzen
  - trigger: rest
    resource: https://enever.nl/api/gasprijs_vandaag.php?token=my code is removed here
    unique_id: enever_gasprijs_anwb
    force_update: true
    unit_of_measurement: €/m³
    value_template: >
      {% for row in value_json.data|reverse if not values.current %}
      {% endif -%}
      {% endfor -%}
      {% else %}
      {% endif %}
and this i changed it to this but i think its good please have a look also here.
automation.yaml
# Enever.nl Update Gasprijs
- id: update_anwb_gasprijs_6uur
  alias: "Update ANWB gasprijs 6 uur"
  triggers:
    - trigger: time
      at: "06:01:23"
  condition: []
  actions:
    action: homeassistant.update_entity
      entity_id:
        - sensor.gasprijs_anwb
- id: update_anwb_gasprijs_7uur
  alias: "Update ANWB gasprijs 7 uur"
  triggers:
    - trigger: time
      at: "07:00:23"
  condition: []
  actions:
      entity_id:
# Enever.nl Update Stroomprijs
- id: update_enever_anwb_kwhprijs_0uur
  alias: "Update electricity price feed"
  description: Update electricity price feed
  triggers:
    - trigger: time
      at: "00:00:10"
  condition: []
  actions:
    - action: homeassistant.update_entity
      data: {}
        entity_id:
          - sensor.enever_stroomprijs_anwb
  mode: single
- id: update_enever_anwb_kwhprijs_uur
  alias: "Update dynamische stroom tarieven"
  description: Update dynamische stroom tarieven
  triggers:
    - trigger: time_pattern
      minutes: "00"
      seconds: "00"
  condition: []
  actions:
      data: {}
        entity_id:
          - sensor.stroomprijs_anwb
  mode: single
Hello Goofus27,
If you are starting out writing automatons, do it in the automation UI editor and once it works, look at the YAML to see what it should look like.
There are numerous indentation and syntax errors, and that is an automation that can only be in automation.yaml, not in configuration.yaml.
The best way to learn is to just try. Run thru the docs on getting started with the automation editor. If you get stuck, come back with what you have done.
and
The Home Assistant Cookbook - Index.
