Energy consumed day & yesterday
I have a P1 energy meter from Homewizard. It gives me total Energy usage consumed from the net (energy tariff 1 and 2). My sonar panels are producing energy. So in the energy dashboard i see what the total consumtion is for a day what is consumed from the net.
What i would like is the total energy consumed (without produced with solarpanels) so the total consumtion.
I have made a helper which shows me consumtion of the day taken from the net but not the bruto consumtion which the house consumed.
Is this possible to create in a helper?
It would be nice to have total consumtion added with produced and consumed from solarpanels because that is the total consumtion?
What i have available:
p1 meter import tarif 1 and 2
p1 meter export
solar panels production (but this is not kWh)
Your question is a bit confusing…
If you’re looking for you actual household energy consumption, it would, on a daily basis, your solar production - your P1 export + P1 import, both expressed in kwh.
It would be easier (also for you, I guess) if you provide numerical examples of what you have, and what you want to achieve.
what i have:
sensor.p1_meter_energie_export - 1.000
sensor.p1_meter_energie_import_tarief1 - 3.000
sensor.p1_meter_energie_import_tarief2 - 1.000
Envoy_production_today: 5.000 kWh
Envoy_production_lifetime: 100.000 kWh
Sensor for Energy Export is what i have totally exported to the net (generated with solarpanels and not consumed)
P1 meter import tariff 1 and 2 is what i have totally consumed
Envoy is what i generate with Solar.
So lets assume above is for today and i have consumed 9.000 kWh total:
In the numbers above you can see that i have consumed 4 kWh from the net and have exported to the net 1 kWh. That means directly consumed from solar panels: 4kWh but the problem is i cannot see:
Total consumtion 9 kWh (only what is consumed from the net)
Directly consumed from solar panels.
If it could be possible to create a helper that displays:
P1 imported t1+t2 + directly consumed from solarpanels
When these 2 are added to each other then i can display that helper in a graph and see the day consumtion off 9 kWh.
House = import t1 + import t2 + PV energy today - export
= 3 + 1 + 5 -1 = 8kWh, not 9kWh.
template:
  - sensor:
      - name: House Consumption
        device_class: energy
        state_class: total # there's a chance that this total could go backwards momentarily due to asynchronous sensor updates so do not use total_increasing
        unit_of_measurement: kWh
        state: >
          {{ states('sensor.p1_meter_energie_import_tarief1')|float +
             states('sensor.p1_meter_energie_import_tarief2')|float +
             states('sensor.envoy_production_today')|float -
             states('sensor.p1_meter_energie_export ')|float }}
        availability: >
          {{ has_value('sensor.p1_meter_energie_import_tarief1') and
             has_value('sensor.p1_meter_energie_import_tarief2') and
             has_value('sensor.envoy_production_today')|float and
             has_value('sensor.p1_meter_energie_export ') }}
thx, i will try this
i have tried the template in developer mode but it gives an error:
value error: template error: float got invalid input unknown when rendering template…followed with the sensors and availability …but no default specified
Did you change the envoy sensor entity id I made up to your actual sensor?
You did not tell us what that one was.
      - name: Energie_huis_verbruik
        total_increasing
        state: >
          {{ states('sensor.p1_meter_energie_import_tarief_1')|float +
             states('sensor.p1_meter_energie_import_tarief_2')|float +
             states('sensor.envoy_energy_production_today')|float -
        availability: >
          {{ has_value('sensor.p1_meter_energie_import_tarief_1') and
             has_value('sensor.p1_meter_energie_import_tarief_2') and
             has_value('sensor.envoy_energy_production_today')|float and
above is what i tested in developer mode: i have changed the name of sensors which is for my configuration correct
Remove the |float from that copy and paste mistake I made.Should be:
has_value('sensor.envoy_energy_production_today') and
        state: >
             availability: >
gives the same error
What error exactly?
It is the last line: but no default was specified
Error message:
Do this for each sensor individually until you find the one that is not correct:
 {{ states('sensor.p1_meter_energie_import_tarief_1')|float }}
All the sensors gives a result
Try removing the space inside these single quotes:
For both the state and availability templates.
thats it!
now i paste it in the yaml configuration
i am waiting for a status, in developer mode the sensor has no status: unknown. Restarted HA but this can take a while i guess.
When above works then i can also create a template sensor to create a sensor for kWh used directly from solar panels like this i guess?:
 - name: Energie_eigen_ZP_verbruik
        state: >
          {{ states('sensor.Energie_huis_verbruik')|float -
It should update as soon as one of the sensors changes and all sensors have a valid numeric state.
Sure but don’t forget the availability template. It is important that the sensor only calculates the value when all sensors are reporting a valid value. And you can simplify it to:
        state: >
          {{ states('sensor.envoy_energy_production_today')|float -
             states('sensor.p1_meter_energie_export')|float }}
        availability: >
          {{ has_value('sensor.envoy_energy_production_today') and
             has_value('sensor.p1_meter_energie_export') }}
Your solar produced minus the energy exported is how much solar energy you used. Things only become more complicated if you have a battery.
