got it, thanks for the clarification!
Can anyone give me the state of play for local control of a PC191HA? This one I’ve got is 1.1.17 so apparently OTA doesn’t work any more, but I’m supes unfamilly
Nothing has changed, you need to open up as described above. I recently bought some series 3 plugs and converted all 4.
Nightmare fuel, ty
Anyone else struggle with the Series 3 versions occasionally getting stuck unable to boot properly? I assume a brownout or something, but it’s so intermittent (once every week or so) that it’s very hard to debug.
It will still say it’s connected on my router settings, but is unavailable in HA. I’ve tried various things like enabling safemode and reboot timeout, as well as disabling the webserver and a few other things to try save memory. I also tried a debug sensor for reboot reason but this seems to not elicit anything useful.
# Substitution Variables
substitutions:
device_internal_name: bedroom_fish_tank_light
device_friendly_name: Bedroom Fish Tank Light
device_wifi_name: FishTankLight
device_ip_address: 192.168.68.72
device_sampling_time: 5s
# Globals
globals: ##to set default reboot behavior
- id: wifi_connection
type: bool
restore_value: no
initial_value: "false"
# Board Configuration
esphome:
friendly_name: ${device_friendly_name}
bk72xx:
board: cb2s
framework:
version: dev #1.7.0
# Enable logging
logger:
baud_rate: 0 # disable serial uart logging
# Enable Home Assistant API
api:
reboot_timeout: 0s
# OTA
ota:
- platform: esphome
safe_mode:
disabled: false
reboot_timeout: 10min
num_attempts: 3
# WiFi
wifi:
ssid: !secret wifi_ssid
domain: !secret wifi_domain
power_save_mode: NONE
manual_ip:
static_ip: $device_ip_address
gateway: !secret gateway
subnet: !secret subnet_mask
# ap: # Enable fallback hotspot (captive portal) in case wifi connection fails
# ssid: ${device_wifi_name}
# password: !secret fallback_hotspot_password
# captive_portal:
# Web Server
# web_server:
# port: 80
# version: 2
# include_internal: true
# local: true
# Time
time:
- platform: homeassistant
debug:
# PC191HA basic switch operation - button, relay and LED
# button is momentary on - shows "on" in HA except for the moment the button is being pressed
# LED should have same on/off state as the relay.
# there is also a wifi_LED, but it is not seen from outside the case
binary_sensor: # the button
# ESP32 Internal Binary Sensors
# ESP Status
- platform: status
device_class: connectivity
entity_category: "diagnostic"
disabled_by_default: true # Shows entity in HA, but disabled by default
- platform: gpio
pin: P11
device_class: window
# when button is pressed, toggle the switch on/off
on_press:
then:
- switch.toggle: relay
switch: # the relay
# ESP32 Internal Switches
- platform: restart
disabled_by_default: True
entity_category: diagnostic
- platform: safe_mode
name: Use Safe Mode
device_class: "switch"
- platform: gpio
pin: P8
restore_mode: RESTORE_DEFAULT_ON # default when power is turned on
icon: mdi:power-socket-au
# synchronise the LED with the relay
on_turn_on:
then:
- output.turn_on: button_led
on_turn_off:
then:
- output.turn_off: button_led
output: # the light in the button
- platform: gpio
pin: P26
# restore_mode: always off # default when power is turned on
# PC191HA sensors - power monitoring and wifi signal
# ESP Internal Sensors
# WiFi
- platform: wifi_signal
name: "WiFi Signal dB"
update_interval: ${device_sampling_time}
device_class: "signal_strength"
- platform: copy # Reports the WiFi signal strength %
source_id: ${device_internal_name}_wifi_signal_db
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
unit_of_measurement: "%"
# Uptime
- platform: uptime
on_raw_value:
then:
- text_sensor.template.publish:
state: !lambda |-
int seconds = round(id(${device_internal_name}_uptime_sensor).raw_state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(days ? to_string(days) + "d " : "") +
(hours ? to_string(hours) + "h " : "") +
(minutes ? to_string(minutes) + "m " : "") +
(to_string(seconds) + "s")
).c_str();
# PC191HA includes a BL0937 chip for measuring power consumption
# and BL0937 is a variation of hlw8012, but using inverted SEL pin functionality
- platform: hlw8012
model: BL0937 # note that the model must be specified to use special calculation parameters
sel_pin: # I believe that cf_pin reports either Voltage or Current depending on this select pin
inverted: true # determine whether true reports Voltage
number: P24
cf_pin: # current or voltage (ele_pin: 7)
inverted: true # the logic of BL0937 is opposite from HLW8012
number: P7
cf1_pin: # Power (vi_pin: 8)
number: P6
update_interval: 15s # How often to measure and report values
# PC191HA measures and returns Voltage OR Current according to the value of sel_pin,
# but it can change the value of sel_pin periodically
initial_mode: "VOLTAGE" # reports VOLTAGE or CURRENT
change_mode_every: 4 # how many times to report before swapping between
# reporting Voltage or Current. Note that the first value reported should be ignored as inaccurate
# Adjust according to the actual resistor values on board to calibrate the specific unit
voltage_divider: 775 # LOWER VALUE GIVES LOWER VOLTAGE
current_resistor: 0.0009 # HIGHER VALUE GIVES LOWER WATTAGE
# how the power monitoring values are returned to ESPHome
voltage:
unit_of_measurement: V
accuracy_decimals: 1
filters:
- skip_initial: 2
power:
unit_of_measurement: W
accuracy_decimals: 2
filters:
- skip_initial: 2
# power should simply be current x voltage -- except that the pc191ha doesn't follow that formula.
# Setting current_resistor to give an accurate Amperage does NOT also give the correct Wattage
# so here I calculate current from power and voltage
unit_of_measurement: A
update_interval: "30s"
lambda: |-
return (id(${device_internal_name}_power).state / id(${device_internal_name}_voltage).state);
filters:
- skip_initial: 2
# Interval
interval:
# ESP32 Internal Intervals
- interval: 10s
then:
- if:
condition:
wifi.connected:
then:
- lambda: |-
id(wifi_connection) = true;
else:
- lambda: |-
id(wifi_connection) = false;
text_sensor:
- platform: debug
device:
reset_reason:
icon: mdi:clock-start
