Energy Dashboard Problems
I finally managed to stop my HA from constantly crashing by completely reinstalling it. I have now integrated my Shelly 3EM according to IAmKlaus’s guide and set it up so that the values are displayed in a balanced manner on the dashboard.
However, I’m still encountering the following issue:
The PV generation is being read by OpenDTU and transmitted to HA via MQTT. That part works fine.
I have added PV generation to the dashboard, and it is displayed correctly there as well.
However, the utilized PV power is not being included in the total power usage.
Why is that?
I can’t integrate the export yet because my west-facing balcony power plant unfortunately doesn’t generate enough electricity to feed into the grid.
Attached is the dashboard configuration.
Let me know if you need any help for me! :blush:
Translated with ChatGPT :smiley:
In order to do that the energy dashboard configuration needs a return to grid sensor specified. Even if it always reads 0, you still need to supply a sensor.
Self consumed solar = solar produced - returned to grid.
The calculation is not performed because the return to grid sensor is unavailable.
Create a template sensor that always returns 0 if you never export energy.
Sometimes i will export Energy, but the Helper is first aviable when i exported some energy. But this is not the problem i think, because if i only have PV energy earlier i also got this information in energy use tab.
Oh well if that how you think it works, please feel free to just ignore my advice, and reality.
No No i don’t i have this config. Here is also an export sensor included
And also an sensor for solargen. But i can add the export sensor first when i exported some energy.
But i will try your tip
    sensors:
      # Template sensor for current power comsumption
      power_current:
        friendly_name: "Power Current"
        unit_of_measurement: 'W'
        value_template: >-
            {{ states('sensor.shellyem3_485519d69f48_channel_a_power')|float + states('sensor.shellyem3_485519d69f48_channel_b_power')|float + states('sensor.shellyem3_485519d69f48_channel_c_power')|float }}
        availability_template: "{{
            [ states('sensor.shellyem3_485519d69f48_channel_a_power'),
              states('sensor.shellyem3_485519d69f48_channel_b_power'),
            ] | map('is_number') | min
      # Template sensor for values of power import (active_power > 0)
      power_import:
        friendly_name: "Power Import"
        value_template: >-
          {% if (states('sensor.shellyem3_485519d69f48_channel_a_power')|float + states('sensor.shellyem3_485519d69f48_channel_b_power')|float + states('sensor.shellyem3_485519d69f48_channel_c_power')|float) > 0 %}
          {% else %}
            {{ 0 }}
          {% endif %}
      # Template sensor for values of power export (active_power < 0)
      power_export:
        friendly_name: "Power Export"
        value_template: >-
          {% if (states('sensor.shellyem3_485519d69f48_channel_a_power')|float + states('sensor.shellyem3_485519d69f48_channel_b_power')|float + states('sensor.shellyem3_485519d69f48_channel_c_power')|float) < 0 %}
            {{ (states('sensor.shellyem3_485519d69f48_channel_a_power')|float + states('sensor.shellyem3_485519d69f48_channel_b_power')|float + states('sensor.shellyem3_485519d69f48_channel_c_power')|float) * -1 }}
          {% else %}
            {{ 0 }}
          {% endif %}
      # Template sensor for values of power consumption
      power_consumption:
        friendly_name: "Power Consumption"
        value_template: >-
          {% if (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) < 0 %}
            {{ 0 }}
          {% elif (states('sensor.power_export')|float(0)) > 0 and (states('sensor.power_solargen')|float(0) - states('sensor.power_export')|float(0)) > 0 %}
            {{ (states('sensor.power_solargen')|float(0)) - states('sensor.power_export')|float(0) }}
          {% else %}
            {{ states('sensor.power_import')|float(0) + states('sensor.power_solargen')|float(0) }}
          {% endif %}
      # Template sensor for values of energy Solar generation (solar_power > 0)
      power_solargen:
        friendly_name: "Power Solar Generation"
        value_template: >-
          {% if (states('sensor.balkon_1_power')|float(0) + states('sensor.balkon_2_power')|float(0)) > 0 %}
            {{ (states('sensor.balkon_1_power')|float(0) + states('sensor.balkon_2_power')|float(0)) }}
          {% else %}
            {{ 0 }}
          {% endif %}
  # Sensor for Riemann sum of energy import (W -> Wh)
  - platform: integration
    source: sensor.power_import
    unit_prefix: k
    round: 2
    method: left
  # Sensor for Riemann sum of energy export (W -> Wh)
    source: sensor.power_export
    unit_prefix: k
    round: 2
    method: left
  # Sensor for Riemann sum of energy consumption (W -> Wh)
    source: sensor.power_consumption
    unit_prefix: k
    round: 2
    method: left
utility_meter:
  energy_import_daily:
    source: sensor.energy_import_sum
    name: Energy Import Daily
    cycle: daily
  energy_import_monthly:
    name: Energy Import Monthly
    cycle: monthly
  energy_export_daily:
    source: sensor.energy_export_sum
    name: Energy Export Daily
    cycle: daily
  energy_export_monthly:
    name: Energy Export Monthly
    cycle: monthly
  energy_consumption_daily:
    source: sensor.energy_consumption_sum
    name: Energy Consumption Daily
    cycle: daily
  energy_consumption_monthly:
    name: Energy Consumption Monthly
    cycle: monthly
You need to specify this:
Oh well okay, i understand now. Thanks for your help.
Great thanks to the community. And to @tom_l You do a great job.
Thanks a lot.
I might have a related issue, maybe someone can assist me too?
As soon as my total energy returned for a given hour is higher than my energy consumption, the consumed energy is displayed as 0, even though it’s actually being consumed from solar power:
Even more, there is a negative consumed battery value (not sure if these issues relate, I’ve alreay opened a thread for that specific issue: Energy dashboard - untracked consumption showing up as battery consumed (negative))
As we can see, in generel, solar power produced is being recognized, and as long as I consume some power from grid (calculated from a Shelly 3EM), the bars are displayed in the upper graph.
My energy returned sensor is configured as follows (found somewhere in this forum I think, but not entirey sure):
# ---- Netz Total Power Returned ---- #
- sensor:
    - name: "Netz Total Power Returned"
      unit_of_measurement: W
      device_class: power
      state_class: measurement
      state: >
        {{ min(0,
            states('sensor.shelly_em3_channel_a_power')| float(0) +
            states('sensor.shelly_em3_channel_b_power')| float(0) +
            states('sensor.shelly_em3_channel_c_power')| float(0)
        )| abs}}
      availability: >
          [ states('sensor.shelly_em3_channel_a_power'),
            states('sensor.shelly_em3_channel_b_power'),
Energy consumed:
# ---- Netz Total Power Consumed ---- #
- sensor:
    - name: "Netz Total Power Consumed"
      device_class: power
      state: >
        {{ max(0,
      availability: >
Since I do use 3 inverters and 2 batteries, the solar power consists of multiple sensors. I’m not sure if it makes sense to post it here, since it can clearly be seen, that solar power is being generated, but simply not displayed above.
Essentially, I’ve added the inverter, and one inverter channel as solar sources (directly connected to the home grid), and two extra sensors (one for each battery), that sum up the power generation as soon as the battery is full as solar power. Power, that is being drawn only from the battery (while no solar input power) is being displayed as power consumed from battery (you can see that it’s working for the night times).
Any advice on what I could check would be appreciated, I seem to have gone lost in some rabbit holes here…
