I want to set up the energy dashboard - is it necessary to have all values in kWh or is it also possible to integrate power (w) values which will be calcuated to kWh directly ?
Or do I need to integrate all the values with a Riemann sum before I can use it for the energy dashboard ?
If this is necessary, does the energy dashboard calculate the daily or monthly values on it’s own or do I have to create separate counters with the utility meter before ?
Greets Karl
