Energy Dashboard Time Zone Inaccuracies
Just to level set the energy dashboard itself works fine and calculates all values correctly if you are in the same time zone as the HA server.
Long story short, I set up a home energy monitor and the numbers in the energy dashboard were off by about 1 KW compared to my powerwall. I set up a utility meter helper to calculate the daily energy used and compared it to what the energy dashboard shows and found a discrepancy.
Essentially, the energy dashboard shows you the energy usage for the time zone that you are viewing the dashboard in (not where the server is located). I believe it should always be set to the server’s time zone since you will have inaccurate reporting otherwise.
If you want to test it, just take a look at the energy dashboard in the same timezone where your server is and then change your timezone to something different on your phone or tablet and reload the app/webpage, now you’ll see a different value.
It’s a profile setting.
Sweet didn’t realize this was an option. Setting it to the server time worked, thanks!
The date pickers are still borked though. This issue has been open for years.
