Energy dashboard, water consumption
I’m a HA user from France and have a working installation using zigbee sensors, cams and a “Legrand ecocompteur 412000” energy management module.
From the IP connected module, I can connect the grid consumption meter “Linky”, various pulse-based meters (e.g. tap water counter) and tore signal to read power info from up to 5 power lines.
Linky
Water meter
This said, I can read and display the information from the energy module:
in /config/sensors.yaml
  - platform: command_line
    name: EcoCompteur Consommation
    command: curl -s 'http://192.168.1.175/data.json' | jq '.conso_base | floor/1000'
    scan_interval: 10
    unit_of_measurement: kWh
    name: EcoCompteur Eau froide
    command: curl -s 'http://192.168.1.175/inst.json' | jq '.data6'
    scan_interval: 2
    unit_of_measurement: m³
    state_class: total_increasing
    device_class: water
The first sensor is for grid consumption: I created a utility meter for this and got it displayed in the dashboard
The second is for water, and whatever configuration I try, I can’t get it to display in the energy dashboard. I have spent hours trying to make it work without success :frowning: I read tens of articles/post etc and I really can’t see anyone displaing water consumption!
I created an utility meter the same way as for the kWh:
and I always get the same message, whether I create the utility meter through the UI or manually:
I also tried to edit the utility meter manually:
Tryed to wait from 5 minutes… to…hours, nada. Statistics exist, played around with state_device, device_class, unit in m3 or m³? rien du tout, nichts, nada
Is there anyone who has ever displayed water consumption in energy dashboard?
Thanks for your assistance
François
Hi there,
got a solution and questions :slight_smile:
To get the water consumption displayed in energy dashboard, it seems that there is a need for state_class and device_class parameters while it’s not necessary for kWh ! don’t know why !
With command_line platform, state_class and device_class don’t report any setting fault but are not supported in documentation.
So I use the rest platform (I didn’t find it by myself !) :slight_smile:
/config/configuration.yaml
rest: !include config_rest.yaml
/config/config_rest.yaml
  # LEGRAND EcoCompteur - m3
  - resource: http://192.168.1.175/inst.json
    scan_interval: 5
      - name: EcoCompteur Eau froide
        unique_id: ecocompteur_eau_froide
        value_template: '{{ value_json.data6 }}'
        device_class: water
then it appears in the dashboard: yessssssssss! well it’s not perfect as it shows in L instead of m3 as expected. The calculation is correct (cost and volume).
I guess there are some limitations here and there, some improvements to the source code to be made, but as long as there is a workaround to reach the goal, it will remain as it is.
There is maybe another way to get the correct volume unit but to me it’s good enough for the moment.
PEF
