Energy Flow Card Plus - Problem home whitout battery
Hello :slight_smile: ,
i use the plugin Energy Flow Card Plus with battery, home,…
I have a data problem.
My battery is connected to a domestic outlet so it is integrated into the consumption data of the rest of my house when it is recharged
Do you have a solution so that I can display the power consumption by subtracting my battery?
You’ll likely need a template sensor or two to use instead.
Thanks for you return,
Can’t I create an entity that takes my input and subtracts my battery?
“real home consumption” = (“home measured consumption” - “battery consumption”).
and source that entry for my house?
Yes you can do that.
Can you tell me how?
I wanted to make an “input” of type “template” but which one to select?
You want “Template a Sensor”.
