Energy looks way off (SDR -> MQTT -> HA)
I setup a SDR using a RasPi and have the system push my gas and electric data through MQTT to HA. I have left things alone to see if anything adjusts but the values seem to be way off. Maybe a decimal issue but as you can see my HA dashboard is showing a usage of 100-200 kWh. I normally use about 1000 kW in a month. Same issue looks with my gas meter reading, it shows me using 6 cubic ft just today when I only use about 20 cubic ft in a summer month.
I included my MQTT explorer data along with my sensor config info
Any thoughts?
  - name: "Kilowatt Hours"
    state_topic: "pipower/ERT-SCM/56698974"
    unit_of_measurement: 'kWh'
    force_update: true
    value_template: "{{ value_json.consumption_data }}"
    unique_id: "kilowatt_hours_sensor"
    device_class: energy
    state_class: total
  - name: "Cubic Feet"
    state_topic: "pipower/SCMplus/78848978"
    unit_of_measurement: 'ft³'
    force_update: true
    value_template: "{{ value_json.Consumption }}"
    unique_id: "cubic_feet_sensor"
    device_class: gas
    state_class: total
