Energy reading numbers do not match
I setup Energy and there are numbers do not match. For the same sensors. Each sensor has this problem. Here is the example. As you can see, it says 0.63kWh
When I click on that sensor, I have different number. Here it says 1.528kWh
It is like this for all of my sensors in Energy section. Why is this?
The energy dashboard only reports the energy consumption for the selected day. It calculates the difference of “energy total” between beginning and end of day.
Whereas your graph shows the total since beginning of measurement.
I understand what it shows, but why does it show different numbers when I hover above and when I click on the same sensor?
I can not identify any difference on your screenshots, apart from what I described.
Oh, maybe I do understand now.
What you see when hovering is not the sensor, but a calculated value based on the sensor and relevant in this context. When you click on it, you see the actual sensor.
