I have installed a Shelly3EM in my home and it works fine. Now I did the same at my sister’s house, but there I do not get any energy values within the energy template. All “L1, L2, L3 Energy” values stay at 0. I do get “L1, L2, L3 Current, Power, Power Factor, and Voltage”. So it seems that the Shelly3EM is installed correctly.
I made a restart of the Shelly3EM and I also deleted the Shelly Integration from the devices. After restart of HA the Shelly3EM was found automatically again but still the energy values are 0.
Here are some lines fron the debug log:
2023-01-18 11:01:10.052 DEBUG (MainThread) [aioshelly.block_device.coap] CoapMessage: ip=192.168.2.254, type=periodic(30), payload={'G': [[0, 9103, 0], [0, 1101, 0], [0, 4105, 282.72], [0, 4106, 0.0], [0, 4107, 0.0], [0, 4108, 231.96], [0, 4109, 1.75], [0, 4110, 0.7], [0, 4205, 70.02], [0, 4206, 0.0], [0, 4207, 0.0], [0, 4208, 232.95], [0, 4209, 0.37], [0, 4210, 0.81], [0, 4305, 182.11], [0, 4306, 0.0], [0, 4307, 0.0], [0, 4308, 234.83], [0, 4309, 0.92], [0, 4310, 0.85], [0, 6102, 0]]}
2023-01-18 11:01:10.053 DEBUG (MainThread) [aioshelly.block_device.coap] Calling CoAP message update for device 192.168.2.254
2023-01-18 11:01:10.053 DEBUG (MainThread) [homeassistant.components.shelly] Manually updated Shelly3EM data
2023-01-18 11:01:10.054 DEBUG (MainThread) [homeassistant.components.shelly] Skipping non-input event block relay_0
2023-01-18 11:01:10.054 DEBUG (MainThread) [homeassistant.components.shelly] Skipping non-input event block emeter_0
2023-01-18 11:01:10.054 DEBUG (MainThread) [homeassistant.components.shelly] Skipping non-input event block emeter_1
2023-01-18 11:01:10.055 DEBUG (MainThread) [homeassistant.components.shelly] Skipping non-input event block emeter_2
2023-01-18 11:01:10.055 DEBUG (MainThread) [homeassistant.components.shelly] Skipping non-input event block device
2023-01-18 11:01:25.058 DEBUG (MainThread) [aioshelly.block_device.coap] CoapMessage: ip=192.168.2.254, type=periodic(30), payload={'G': [[0, 9103, 0], [0, 1101, 0], [0, 4105, 290.35], [0, 4106, 0.0], [0, 4107, 0.0], [0, 4108, 232.2], [0, 4109, 1.78], [0, 4110, 0.71], [0, 4205, 70.34], [0, 4206, 0.0], [0, 4207, 0.0], [0, 4208, 233.07], [0, 4209, 0.37], [0, 4210, 0.81], [0, 4305, 159.45], [0, 4306, 0.0], [0, 4307, 0.0], [0, 4308, 235.09], [0, 4309, 0.8], [0, 4310, 0.85], [0, 6102, 0]]}
2023-01-18 11:01:25.058 DEBUG (MainThread) [aioshelly.block_device.coap] Calling CoAP message update for device 192.168.2.254
2023-01-18 11:01:25.059 DEBUG (MainThread) [homeassistant.components.shelly] Manually updated Shelly3EM data
2023-01-18 11:01:25.060 DEBUG (MainThread) [homeassistant.components.shelly] Skipping non-input event block relay_0
2023-01-18 11:01:25.060 DEBUG (MainThread) [homeassistant.components.shelly] Skipping non-input event block emeter_0
2023-01-18 11:01:25.060 DEBUG (MainThread) [homeassistant.components.shelly] Skipping non-input event block emeter_1
2023-01-18 11:01:25.060 DEBUG (MainThread) [homeassistant.components.shelly] Skipping non-input event block emeter_2
2023-01-18 11:01:25.061 DEBUG (MainThread) [homeassistant.components.shelly] Skipping non-input event block device
A screenshot of the sensors is here:
What can I do to solve the problem?
