I’m using Emoncms to store my power usage (W and kWh)
I also push (every 5 minutes) the readings from my water meters (cold/hot/rain) to Emoncms. (the feed is set to m3)
I made a connection to Emoncms in HomeAssistant and i’m getting the data.
The sensor is allowing me to change the “meeteenheid” to m³, L etc (so i’m guessing it correctly understands that the info is in m3)
However on the “Energyconfiguration” it says that there are no corresponding statistics found (Geen overeenkomende statistieken gevonden)
Any idea what i’m doing wrong?
