Enerwave dual relay weirdness since 12.24 update
Hello.
I was running HA release 12.23 for awhile. Recently I updated to 12.24 and then 1.25 . Since the 12.24 update my enerwave dual relay (https://topgreener.com/product/smart-z-wave-dual-relay-switch-module/) is not working right. Prior my automation turned on both devices that were connected to the dual relay. Now when the relay triggers instead of turning them both on, the first relay goes on and activating the second channel will turn off the first and not turn on the second. Same thing happens if turn on second channel first. Same action is also happening via using the switches. One item I noticed is HA is not updating the status of the relay.
My initially thought is this relay went bad or the 12.24 update caused issues. Curious to see if others are having the issue?
EDIT: device finally stopped working. device is defective
Hi autosacing,
I’m not sure that anyone can help you as I for one do not know of a 12.24 release of home assistant unless you are talking about something that happened in 2017.
Could you please help us help you by providing real revisions?
