Enhanced Recorder Filtering - Exclude States (e.g., 'unknown', 'unavailable')
Description:
Currently, the Home Assistant Recorder integration allows filtering of recorded data based on entities, domains, and event types. However, there is no built-in functionality to exclude specific states (e.g., unknown, unavailable) from being recorded.
In many setups, sensors may frequently report unknown or unavailable states due to temporary connectivity issues or other transient problems. Recording these states can lead to unnecessary database bloat and negatively impact performance, without providing any useful historical data.
Proposed Solution:
I propose adding a new feature to the Recorder integration that allows users to exclude specific states from being recorded. This could be implemented as a new exclude_states option within the recorder configuration, similar to the existing exclude_entities and exclude_event_types options.
Example Configuration:
yaml
Copy Code
recorder: exclude: entities: - sensor.example_sensor event_types: - call_service states: - unknown - unavailable
In this example, the Recorder would exclude all unknown and unavailable states from being recorded, regardless of the entity or event type.
Benefits:
  • Reduced Database Size: By excluding unnecessary states, the database size can be significantly reduced, leading to improved performance and reduced storage requirements.
  • Improved Data Quality: Excluding transient states results in a cleaner and more meaningful historical dataset.
  • Resource Savings: Less frequent database writes reduce CPU and I/O load on the Home Assistant system.
Use Case:
I have approximately 3000 sensors in my Home Assistant setup, and many of them occasionally report unknown states. Manually excluding each sensor or performing regular database cleanup is not a scalable solution. A built-in feature to exclude specific states would greatly simplify the management of recorded data and improve the overall performance of my Home Assistant system.
Then you should fix your set up so this does not happen. You will have a more reliable system and your DB will be slightly smaller.
Also the unavailable states are required for the frontend graphs to represent your device history correctly.
Also if you are running HA OS I recommend you install the DbStats add-on so you can see what is really bloating your DB. It is unlikely to be just unavailable states.
There are other use cases that can get benefit from this proposal.
For example, when I’m playing music in a speaker, I can see the media_player entity spamming the logbook with states “playing” and “buffering”, constantly being repeated.
I want to record when is off or on, etc, but I totally don’t need the “buffering” state being recorded every few seconds in the logbook.
