Enigma2 (actionable) notifications
It would be great to have a notification service running on the Enigma2 integration.
@cinzas did a geat job already with his custom component homeassistant-enigma-player but his work never found it’s way in the official enigma2 integration:
Above that, the reply of actionable notifications should be usable on HA as well.
@cinzas , maybe it is possible to use your notification componente with the official Enigma2 platform?
Hi @Pe-MaKer,
I tried a PR with my component, but I also did not get the time to finish it.
Someone submitted the component already. I still use mine :slight_smile:
In any case is just a matter of implementing the notification part of my component into the current enigma platform of HA.
Cheers
Thanks for your fast reply.
@fbradyirl maybe you can help out here. Would it be feasible for you to add the notification component to the enigma2 integration?
@cinzas maybe You could fix that https://github.com/home-assistant/home-assistant/issues/28134 I think in your version of integration it works better so how about PR to official one ? :slight_smile:
