EnOcean BLE — native support for PTM 215B / PTM 216B energy-harvesting switches
Hi everyone,
I just published EnOcean BLE on HACS — a custom integration for EnOcean BLE energy-harvesting wall switches (PTM 215B / PTM 216B).
These are the kinetic, battery-free switches that generate power from the button press itself. No wiring, no batteries — ever. They communicate over standard BLE 2.4 GHz.
Already using these switches in another ecosystem?
PTM 215B/216B switches are the hardware core behind several commercial ecosystems. If you're running any of the following and want to bring your switches into Home Assistant — this integration is for you:
  • Casambi — AIMOTION Switch 55, Tunto Wireless Switch, Kopp Blue-control and others use PTM 215B/216B as their kinetic transmitter
  • ABB free@home — Busch-Jaeger 6716 UBT Smart Switch insert
  • Niko Home Control — Niko Dimmer Switch Bluetooth
  • Feller EDIZIOdue (Switzerland) — Feller BLE Funktaster (single and double rocker)
  • Eltako — FTE215BLE wireless pushbutton
  • Vimar By-me / View — Vimar 03925 4-button BLE device
  • Hytronik — HBES01 kinetic wall switch
The switches themselves are not locked to their original ecosystem at the radio level — this integration communicates directly with the PTM 215B/216B BLE module, independently of any gateway or hub.
Note: you may need to factory-reset the switch if it was previously configured with a custom security key by the original ecosystem. See the README for the reset procedure.
What it does
  • Bluetooth auto-discovery + guided commissioning flow (no YAML, no manual key entry)
  • Secure telegram parsing with AES-128 MIC verification
  • 4 event entities (A0, A1, B0, B1) + 4 sensor entities per device
  • Handles BLE packet loss gracefully: detects lost press/release, fires synthetic events when appropriate
Event model
Layer Events When to use
Simple (guaranteed) single_press Toggle, scene, one-shot
Advanced (best-effort) press, release, long_press, long_release On/off by gesture, dimming
Safety net release_timeout, orphan_release Automation cleanup on packet loss
single_press fires immediately on the press telegram — robust to a lost release. If the press is lost in BLE, it fires on a coherent orphan release (sequence gap == 2). Use one mode per button; do not mix single_press with advanced events.
Supported hardware
Any wall switch built around the EnOcean PTM 215B or PTM 216B module. See the README for the full confirmed product list.
Not for sub-1 GHz EnOcean switches (868/902 MHz PTM 210/215) or Zigbee Green Power (PTM 215Z/216Z). BLE 2.4 GHz only.
Quick example — simple toggle
alias: EnOcean A0 - Toggle light
mode: single
triggers:
  - trigger: state
    entity_id: sensor.my_switch_a0_event
    to: single_press
actions:
  - action: light.toggle
      entity_id: light.living_room
Installation
HACS → Integrations → Custom repositories → add https://github.com/Superkikim/enocean-ble, category: Integration.
Or search EnOcean BLE directly in HACS if it's already indexed.
Links
Happy to answer questions. If you have one of these switches and hit a problem, open an issue with your device model and I'll look into it.
