EnOcean DC-GW/EO-IP with home assistant
I have a DC-GW/EO-IP enocean gateway on my local network and i’m trying to integrate the sensors connected to it to my home assistant instance.
I was thinking about using the node red add on to send the devices config and data via mqtt and then read the data from home assistant (if everything goes well i can probably even set up Autodiscovery for the devices).
With this topic i would ask to anyone who can help if it’s a good starting point or if there is a more effective way to set things up with this gateway.
The material i have found till now is all about using an usb stick connected to the machine running HA (but i can’t do it since it is a virtualized docker container on the cloud).
I should also add that HA and the gateways are on different network.
Thanks.
