EnOcean EEP A5-14-01 Protocol Support for Window Contacts
I am still relatively new to HA. I am using an EnOcean based window contact (Eimsig) sensor with the EEP A5-14-01 protocol and trying to integrate it into HA, with no success so far.
I check the documentation but couldn’t find the protocol specifically listed, however, it is said that devices most probably are supported if they use one of the know EnOcean profiles, as the one above mentioned.
I am using the USB300 stick in an USB slot of my HA server and it seems working.
Any idea what I can try to find the problem why the EnOcean integration does not find any of my sensors?
Thanks for your help!
Andreas
