I’ve tried everything I can think of. Attempting to make a bedside keyboard to turn on and off lights with LED indicators. So far I cannot get any entity to show up other than firmware.
esphome:
friendly_name: 10Pad
esp32:
board: wemos_d1_mini32
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "***********************************"
ota:
- platform: esphome
password: "********************************"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "10-Pad Fallback Hotspot"
password: "**********"
captive_portal:
matrix_keypad:
rows:
- pin: GPIO3
- pin: GPIO1
columns:
- pin: GPIO0
- pin: GPIO4
- pin: GPIO5
- pin: GPIO2
- pin: GPIO14
keys: "123456789A"
has_diodes: false
on_key:
- lambda: ESP_LOGI("KEY", "key %d pressed", x);
binary_sensor:
- platform: matrix_keypad
key: 1
icon: mdi:button-pointer
key: 2
key: 3
key: 4
key: 5
key: 6
key: 7
key: 8
key: 9
key: A
light:
- platform: esp32_rmt_led_strip
chipset: WS2812
rgb_order: GRB
pin: 13
num_leds: 10
rmt_channel: 3
name: 10P RGB LED
effects:
- random:
- flicker:
- addressable_rainbow:
- strobe:
- flicker:
alpha: 95%
intensity: 10%
speed: 50
- platform: partition
name: "10P LED 1"
segments:
- id: p10_rgb_led
to: 0
name: "10P LED 2"
segments:
- id: p10_rgb_led
to: 1
name: "10P LED 3"
segments:
- id: p10_rgb_led
to: 2
name: "10P LED 4"
segments:
- id: p10_rgb_led
to: 3
name: "10P LED 5"
segments:
- id: p10_rgb_led
to: 4
name: "10P LED 6"
segments:
- id: p10_rgb_led
to: 5
name: "10P LED 7"
segments:
- id: p10_rgb_led
to: 6
name: "10P LED 8"
segments:
- id: p10_rgb_led
to: 7
name: "10P LED 9"
segments:
- id: p10_rgb_led
to: 8
name: "10P LED 10"
segments:
- id: p10_rgb_led
to: 9
