Entities/Device/Area dropdown selection not working properly
And what about the ’ in “B’s ipad”?
That was the onef the three signs I was most concerned about.
Yes, even that, I will try to remove åöä characters too, need to find the time. :slight_smile:
update:
Same thing, it didn’t work… :frowning:
I am sorry to hear.
I think you might have to get some helps from the developers to hunt the problem down.
I will still bet my hat that it is one of you entity’s or device’s properties that cause a formatting issue in NodeRed.
The developers knows better what is used where and in what order, which is quite relevant here.
Ok, thanks for the help!
It’s probably as you say but I can’t find anymore strange characters now.
Should I try help here at home assistant forum or in the node red forum?
Regards Boz
Look at this post.
Thanks @WallyR,
If found out if I changed the css(directly in the browser) from:
.select2-container .select2-selection–multiple .select2-selection__rendered {
display: contents;
list-style: none;
padding: 0;
to:
display: grid;
list-style: none;
padding: 0;
it worked better but I’m not sure how to get this fixed permanently in my environment.
Any ideas?
I posted my problem in the
but there was no response at all there.
I think you need a response from frenck
