I have noticed that some of my shelly devices seem to have either multiple devices and/or entities mapped to each other which should not be. I would love to figure how I can correct these so they map correctly.
For example the below image you see Dinning Bulb L1 has two devices but it is only 1 bulb so should be one device. Similarly you can see Bulb L2 has 16 entities. Bulb R1 is correct with 1 Device and 9 entities.
Let me break these different scenarios down:
Dinning Bulb L1 has the correct number of entities but for some reason also has another bulb linked to it “Glass Press Bulb”. They both have 9 entities which when clicked on show perfectly fine. Just do not know why the devices are linked.
Dinning Bulb L2 has additional entities coming from a Door/Window sensor. I have no idea why they show under this bulb.
There are a few others with similar scenarios. Can anyone help me clean this up? Thanks.
