Entities missing from group
Hi! I’m new to HA and I’m trying to group some of my entities. I want 3 entities grouped together but I only managed to get 2 in the same group en one alone. This is part of my configuration:
binary_sensor:
    sensors:
      cam_foscam_black_motion_sensor:
        value_template: "{{ states.input_boolean.cam_foscam_black_motion.state == 'on' }}"
        sensor_class: motion
        friendly_name: "Bedroom motion sensor"
switch larm_motion_foscam_black:
  - platform: rest
    resource: http://localhost:8686/outcommand.php?entity=switch.larm_motion_foscam_black
    name: 'Toogle bedroom motion sensor'
    is_on_template: '{{ value_json.state == "ON" }}'
input_boolean:
  cam_foscam_black_motion:
    name: 'Virtual motion sensor bedroom'
    initial: off
group:
  cam_foscam_black_group:
    entities: switch.larm_motion_foscam_black, input_boolean.cam_foscam_black_motion, binary_sensor.cam_foscam_black_motion_sensor
And this is how it looks:
Any suggestions?
Doesn’t look like that switch (larm_motion_foscam_black) is set up correctly, if this is a paste from your config.
Ah, of course! Do you know how it should be written? I can’t figure out how to set the entity id of the switch.
If you look in the developer toos / states - is this really the entry for your entity?
Or do you see a different name there?
No, there is a different name there: switch.toggle_bedroom_motion_sensor
Looks like it takes the name and replaces spaces with underscores to be more ‘variable name’ friendly. Tried to set a friendly name but it didn’t work. As long as I know that this is the way it works I can manage it, but it would be nice to be able to set one display name and one id. Thank you for the help!
switch:
  - platform: rest
You can set a friendly name in your customize: block (which is a child of home_assistant:)
Thank you! That was exactly what i wanted.
