Setting up automations with the UI is easy and straightforward. Used devices/entities are linked to the respective entity details screen.
However, when I “group” different actions in the UI as a block, this connection is not visible. The culprit seems to be the use of “execute actions sequentially” in the automation UI. Without it, things are ok.
correctly translates to YAML
- sequence:
- type: turn_off
device_id: 60342f9dcbcfa2eb2d6ce708fc4bc581
entity_id: d96ecd9bccbd1a6d580bc0bb97bcf2d2
domain: switch
- action: cover.open_cover
metadata: {}
data: {}
entity_id:
- cover.kuche_erker_1
- cover.kuche_erker_2_3
Entity cover.kuche_erker_1 has been assigned the name Küche Erker 1, which is the alias for m000214.motor2
. Its device info screen is not displaying the automation:
