Entities not showing up in Node Red
I already have a few flows working in Node Red.
I am trying to add a new flow shared by a user here, and even after changing the “Server” i am not able to see none of the light switches, sensors, or for that matter any device in the entity. I have restarted the Node-Red service, also restarted HA server. Inspite of that it did not help.
Please guide.
I have the same problem :frowning: existing flow is working but can’t any entities if creating a new flow.
Yea and no one is ready to help, i have three other posts on different subjects with minimal support from anyone.
hi… I did the hard way :slight_smile: I exported all my flows and renamed my node-red folder I HA then starts up from as new, then imported my flows, and now it all is working :slight_smile:
same problem here after all the updates… any solution?
Did you read the response above yours?
