Entity-filter card regex filter won't work
Something is wrong with my entity-filter card configuation, but I can’t find the reason why. The card gives no output.
Sensor:
Lovelace card config:
type: entity-filter
entities:
  - entity: sensor.seventeentrack_package_511817441021
state_filter:
  - operator: regex
    value: "(\bdelivery\b)"
    attribute: info_text
card:
  type: glance
show_empty: false
Thanks for your help!
~Marlon
Try it this way:
    value: "\bdelivery\b"
Thanks, but still the same ;-;
What about
value: ".*delivery.*"
Tried this with some random sensor, but the regex thingy seems pretty much broken, if you ask me, or I’m missing something.
Yes it is, but
from @Troon seems to work.
OK, so it looks like it’s wanting the regex to match the entire attribute, rather than the conventional meaning of a regex match.
Maybe someone should fix the docs for this card.
They also did there some grouping like in my first try:
value: "^([0-7]{1})$"
Links to allow you to do that are at the bottom of that page :wink: .
The example works because they’re matching the entire attribute.
