Entity-Filter-Card with filtered entities on power consumpion
Hi there
I would like to see a card with a list of zigbee switches when their current sensor shows up a value greater than a minimum. Then push the switch and this switch (OFF) disappear.
How could I do that in homeassistant current version (creation timestamp of this msg) ?
I have been spending already 2 days (!) trying to define templates but then no visualization on a dashboard. Not really “off-the-shelf” ;))))
Thanks a lot in advance! (even for a small example)
PS: I would prefere NOT to use HACS because of the inherent privacy threats
I replay to myself to this.
For the very moment I decided to implement this simple thing with 2 vertical stacks having the same entity-cards but different visibility conditions.
For example in left stack (OFF) for each entity-card a visibility condition to show only cards with devices with power consumption > 1W; and in right stack (ON) a visibilty condition to show only cards with devices with power consumption < 1.
INTERESTINGLY there is no inbetween (power = 1W)
This does what I wanted and will probably survive 10 generations of HA.
