Entity_id not determined by way of variable
Hi all
I don’t get the entity_id to work in automations other than to “hard-code” it. The service part works 100%.
value will be "on or “off”
item will be “home” or “away”
  - alias: Receive Message
    - platform: webhook
      webhook_id: alarm_pw
      service: >
        input_boolean.turn_{{ trigger.json.value }}
      entity_id: >
        input_boolean.alarm_{{ trigger.json.item }}
Any help will be appreciated
Thank you
Can you show an example of the JSON you receive?
entity_id employs a template so you should use data like this:
    - platform: webhook
      service: >
        entity_id: >
Thank you 123 Taras - it worked!
