Entity is not responding to toggle
Hi, I have added a smart switch through Tuya/smartlife integration, Initially it got configured and worked as expected.
however i tried to change some configuration for mushroom dashboard, one of the entity(Switch button) shows as entity but does not work.
there are 7 swiches plus 1 master switch to on/off, 6 switches are working in dashboard but 7th switch has its name out of sync (switch 8) is not working. toggle is not working.
I tried to remove device, changing entity name but did not work.
please let me know, what i am doing wrong
Can you provide a gif or video that shows your issue?
