Can I set entity picture for different states?
I want to use photos of my lamps when turned on and when off as entity picture.
Picture entity card?
For template sensors you may use something like this:
template:
- sensor:
- name: xxxxxxxxxxxxx
state: ....
picture: >-
{% if ....... -%}
/local/images/test/orange.jpg
{%- else -%}
/local/images/test/blue.jpg
{%- endif %}
But if you need to define dynamic images for a “light” entity - probably the only way is customizing by Custom UI (check for details in a corresponding thread in the Community).
Also, if you need to define pictures on particular card only - no need to customize the entity, check for available appropriate “image” option of the card.
I want the on/off button to show different pictures for on and off. If you have any solution for that, let me know.
