Log Details (ERROR)
Sun Jul 22 2018 13:17:59 GMT-0700 (Pacific Daylight Time)
Error during setup of component envisalink
File “E:\Python\lib\site-packages\homeassistant\setup.py”, line 143, in async_setup_component
hass, processed_config)
File “E:\Python\lib\site-packages\homeassistant\components\envisalink.py”, line 87, in async_setup
from pyenvisalink import EnvisalinkAlarmPanel
File "C:\Users\rob\AppData\Roaming.homeassistant\deps\Python37\site-packages\pyenvisalink_init.py", line 2, in
from .envisalink_base_client import EnvisalinkClient
File “C:\Users\rob\AppData\Roaming.homeassistant\deps\Python37\site-packages\pyenvisalink\envisalink_base_client.py”, line 14
from asyncio import async
SyntaxError: invalid syntax
I’ve tested the username / password / ip by directly going to the ip logging in and seeing the alarm status. I’ve tested with removing all zones and partitions and everything not “required” and I always get invalid config error.
That configuration doesn’t have the port I forgot to put it back in but it should default and I’ve tested with and without many times.
I’m very new to HA (1 day) and I’m starting to think its more of an issue with my install on windows 10 than the component itself.
I’m tempted to go buy another pi and just start over to rule out the OS windows 10.
Thank you very much for your reply. I did spend a lot of time reviewing the formatting even installed notepad++ to try and help.
I’m pasting it here again, I hope its better for review.
I just redid all the text for envisalink in the configuration.yaml. (my wink hub is being discovered and ignored until I get authenticated.
2018-07-22 17:45:34 ERROR (MainThread) [homeassistant.setup] Error during setup of component envisalink
2018-07-22 17:45:49 WARNING (SyncWorker_39) [netdisco.ssdp] Error fetching description at http://127.0.0.1:58080/2b43d64248.xml
2018-07-22 17:45:49 WARNING (SyncWorker_39) [netdisco.ssdp] Error fetching description at https://192.168.1.151:8888
2018-07-22 17:45:50 ERROR (MainThread) [homeassistant.setup] Error during setup of component wink
File “E:\Python\lib\site-packages\homeassistant\setup.py”, line 146, in async_setup_component
component.setup, hass, processed_config) # type: ignore
File “E:\Python\lib\concurrent\futures\thread.py”, line 57, in run
File "E:\Python\lib\site-packages\homeassistant\components\wink_init.py", line 228, in setup
from pubnubsubhandler import PubNubSubscriptionHandler
File “C:\Users\rob\AppData\Roaming.homeassistant\deps\Python37\site-packages\pubnubsubhandler.py”, line 10, in
from pubnub.pubnub import PubNub
File “C:\Users\rob\AppData\Roaming.homeassistant\deps\Python37\site-packages\pubnub\pubnub.py”, line 104
self._pubnub.time().async(self._call_time_callback)
I don’t have Envisalink, so I can’t pinpoint 100%… but I would start by taking out everything that is optional and see if it loads error free. Then add the optional items and see what causes the error
Thank you very much forsquirl, you’ve been really helpful.
I already tried removing all the optional parts but still couldn’t it it working.
I just ordered another PI and I’m going to install HA they its designed and test again. I will also follow up in this post after its arrived and I’ve set it up.
Just to follow up, I bought a PI3 and installed HASS.IO and the envisalink works well now.
I haven’t setup arm and disarm buttons but it checks and updates zones.
