Any Envisalink users here that have succeeded in getting the status of their Envisalink Module (Honeywell alarm panel, evl4) into more than one HA instance - e.g. live and test - at the same time?
It looks like I can’t log into the module from my test setup while the live instance is connected to it.
Login via the web interface while one of the HA instances is up & running doesn’t seem to be an issue, though.
Nope - as you can see, I never got a reply from anybody - so in the end: I leaned to live with it.
I’ve also started using MQTT heavily since then, which I could probably use for this - but it would probably be more trouble for me at the moment than it’s wort.
Sorry!
"IMPORTANT: Envisalink Application Firewall
As of Envisalink 4 (1.0.102) and Envisalink 3 (1.12.180) the Envisalink has an internal firewall that will block all TPI
connections that originate outside of the network segment it resides upon. This is to protect users who expose their
Envisalinks to the public Internet either by mistake or ignorance. This feature can be disabled by changing the default
user’s password from “user” to any other password, 4 characters or longer.
3.0 Detailed Description of the Feature "
