Envisalink Zone Binary Sensors not updating
I have a the integration working fine from a standpoint of arming/disarming and such, but it seems my sensors configured in the configuation.yaml file are not updating in HA.
Example:
Config:
envisalink:
  host: 192.168.1.117
  panel_type: HONEYWELL
  user_name: !secret envisa_username
  password: !secret envisa_password
  code: !secret envisa_code
  port: 4025
  evl_version: 4
  keepalive_interval: 60
  zonedump_interval: 20
  timeout: 10
  panic_type: Police
  zones:
    1:
      type: "opening"
    2:
      type: "opening"
    3:
      name: "Garage Door Interior"
      type: "opening"
    4:
      name: "Garage Door Exterior"
      type: "opening"
    5:
      name: "Front Living Motion"
      type: "motion"
    6:
      type: "motion"
    7:
      type: "motion"
    8:
  partitions:
    1:
You can see last tripped time as late night 6/2, but I restarted my HA instance and it returns atrip on restart… I’ve clearly tripped that sensor this morning a few times but still nothing in my end. I have nothing in the logs around errors or failures that I see.
I do want to add, it seems the “opening” sensors do work fine… it’s the motions that aren’t returning the last tripped time.
I’m having the same problem using Envisalink configuration for a DSC panel. Changes are immediate in EyezOn app and portal, as well as on my Vera controller.
The only thing in the logs it shows is when I restart HA. Did you figure out what is going on?
Nope… but what I did figure out: If the alarm is armed, the system doesn’t report back the state change status. only when it’s disarmed.
Are you connecting your HA directly to envisalink or via a proxy ? (like dscserver ?)
