Good afternoon, I am trying to integrate the solar panels. The equipment is enphase Envoy. HA has detected the equipment but when configuring I get the following error.
I also attached the log.
I am new to this, so I would greatly appreciate your help and explanation.
Logger: homeassistant.components.enphase_envoy.config_flow
Source: components/enphase_envoy/config_flow.py:42
Integration: Enphase Envoy (documentation, issues)
First occurred: 23:07:46 (2 occurrences)
Last logged: 23:08:00
Unexpected exception
File “/usr/src/homeassistant/homeassistant/components/enphase_envoy/config_flow.py”, line 150, in async_step_user
envoy_reader = await validate_input(self.hass, user_input)
File “/usr/src/homeassistant/homeassistant/components/enphase_envoy/config_flow.py”, line 42, in validate_input
await envoy_reader.getData()
File “/usr/local/lib/python3.10/site-packages/envoy_reader/envoy_reader.py”, line 136, in getData
await self.detect_model()
File “/usr/local/lib/python3.10/site-packages/envoy_reader/envoy_reader.py”, line 166, in detect_model
await self.get_serial_number()
File “/usr/local/lib/python3.10/site-packages/envoy_reader/envoy_reader.py”, line 218, in get_serial_number
full_serial = await self.get_full_serial_number()
File “/usr/local/lib/python3.10/site-packages/envoy_reader/envoy_reader.py”, line 228, in get_full_serial_number
response = await self._async_fetch_with_retry(
File “/usr/local/lib/python3.10/site-packages/envoy_reader/envoy_reader.py”, line 128, in _async_fetch_with_retry
return await client.get(url, timeout=30, **kwargs)
File “/usr/local/lib/python3.10/site-packages/httpx/_client.py”, line 1757, in get
return await self.request(
File “/usr/local/lib/python3.10/site-packages/httpx/_client.py”, line 1533, in request
return await self.send(request, auth=auth, follow_redirects=follow_redirects)
File “/usr/local/lib/python3.10/site-packages/httpx/_client.py”, line 1620, in send
response = await self._send_handling_auth(
File “/usr/local/lib/python3.10/site-packages/httpx/_client.py”, line 1648, in _send_handling_auth
response = await self._send_handling_redirects(
File “/usr/local/lib/python3.10/site-packages/httpx/_client.py”, line 1685, in _send_handling_redirects
response = await self._send_single_request(request)
File “/usr/local/lib/python3.10/site-packages/httpx/_client.py”, line 1722, in _send_single_request
response = await transport.handle_async_request(request)
File “/usr/local/lib/python3.10/site-packages/httpx/_transports/default.py”, line 353, in handle_async_request
resp = await self._pool.handle_async_request(req)
File “/usr/local/lib/python3.10/site-packages/httpcore/_async/connection_pool.py”, line 253, in handle_async_request
raise exc
File “/usr/local/lib/python3.10/site-packages/httpcore/_async/connection_pool.py”, line 237, in handle_async_request
response = await connection.handle_async_request(request)
File “/usr/local/lib/python3.10/site-packages/httpcore/_async/connection.py”, line 86, in handle_async_request
raise exc
File “/usr/local/lib/python3.10/site-packages/httpcore/_async/connection.py”, line 63, in handle_async_request
stream = await self._connect(request)
File “/usr/local/lib/python3.10/site-packages/httpcore/_async/connection.py”, line 150, in _connect
stream = await stream.start_tls(**kwargs)
File “/usr/local/lib/python3.10/site-packages/httpcore/backends/asyncio.py”, line 78, in start_tls
raise exc
File “/usr/local/lib/python3.10/site-packages/httpcore/backends/asyncio.py”, line 69, in start_tls
ssl_stream = await anyio.streams.tls.TLSStream.wrap(
File “/usr/local/lib/python3.10/site-packages/anyio/streams/tls.py”, line 122, in wrap
await wrapper._call_sslobject_method(ssl_object.do_handshake)
File “/usr/local/lib/python3.10/site-packages/anyio/streams/tls.py”, line 130, in _call_sslobject_method
result = func(*args)
File “/usr/local/lib/python3.10/ssl.py”, line 975, in do_handshake
self._sslobj.do_handshake()
ssl.SSLCertVerificationError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self signed certificate (_ssl.c:997)
