Eq3 Max! Component failed
The eq3 max! component does not work. I always get an error.
In Web it says:
Invalid config
The following components and platforms could not be set up:
    maxcube
Please check your config.
20:57 setup.py (ERROR) Setup failed for maxcube: Component failed to initialize.
20:57 components/maxcube.py (ERROR) Connection to Max!Cube could not be established.
In configuration.yaml:
maxcube:
  host: 192.168.2.157
#  port: 62910
In SSH Terminal i can ping the Max cube.
I do not understand where the error is.
