Error 409 + File editor not available
First post - excuse me if this is in the wrong place.
Up until today have never had a real problem with Home Assistant that I couldn’t fumble my way through.
Have just updated to 2022.3.8 and all of a sudden I cannot access majority of my addons, including file editor and NodeRed. The addons that are running are Samba Share, DuckDNS, and Terminal / SSH.
If I go to start either file editor or NodeRed I am confronted with the following error:
Can’t create container from addon_a0d7b954_nodered: 409 Client Error for http+docker://localhost/v1.41/containers/create?name=addon_a0d7b954_nodered: Conflict (“Conflict. The container name “/addon_a0d7b954_nodered” is already in use by container “a6ec627a91952c0e8d8ae38362b1daf14c6d9ce40d60331a35aa4a8d27eaf993”. You have to remove (or rename) that container to be able to reuse that name.”)
I have little idea with Docker so don’t quite know where to turn - I see an old fix was potentially using portainer which is no longer an option from what I can see.
Any help is appreciated - just want my NodeRed automations back…
If you have access to the Home Assistant CLI try repairing the supervisor:
ha su repair
Hi Tom, yes have tried that one a few times now. Have also tried uninstalling both node red and file editor and then reinstalling just in case.
Just did a supervisor repair and have noticed that it is unsuccessful. Each processing attempt fails with different variations of the following.
EXT4-fs error (device sda8) htree_dirblock_to_tree:1003: inode #264373: comm dockerd: Directory block failed checksum
Don’t know if this helps
You storage appears to be corrupt.
SD card?
Running on Windows 7 PC through a virtual machine
Well the file system is generating errors:
Apologies for the potentially dumb question but how would one go about sorting this? Reinstalling or something else?
For a VM?
No idea sorry.
Thanks for your help Tom - all fixed. Created a new virtual machine and set up home assistant from a full backup. Hopefully this thread will help if others have the same issue.
